I'm assuming the new kit comes with alloy hubs set for the smaller Europa/Herald/Spitfire bearings ?
Correct, I ordered as standard size as I neglected to confirm the axle size and couldn't find any reference to upgrade in the previous owners notes and receipts.
That will teach me to make assumptions when ordering parts
SKF don't list any bearing sets that will magically make my day, the Japanese companies make some weird bearing sizes so I will delve around the web resources a little more before I give up on that front.
I am sure I could fit the smaller axles but that seems a backwards step so if any machining takes place it is on the hubs.
The outer bearing isn't a big drama, bore out the hub and should be fine.
The inner bearing is smaller OD (by about 20 thou) so what I will probably have to do is bore out the hub a little and shrink a sleeve over the bearing.
Tomorrow I will be pulling the rear stub axles for the first time, wish me luck
