Author Topic: Another Ebay TC  (Read 590 times)
Re: Another Ebay TC
« Reply #1 on: Wednesday,May 24, 2023, 03:51:10 PM »
They are definitely quite bent!
Re: Another Ebay TC
« Reply #2 on: Wednesday,May 24, 2023, 04:14:22 PM »
That was apparently the PO’s method of dialing in some negative camber.
Re: Another Ebay TC
« Reply #3 on: Wednesday,May 24, 2023, 07:21:25 PM »
Personally I think Colin would be proud. I mean, an angle as a part has to be the lightest part imaginable.
Re: Another Ebay TC
« Reply #4 on: Thursday,May 25, 2023, 01:09:59 AM »
https://www.ebay.com/itm/385633262747?mkevt=1&mkpid=0&emsid=e11021.m43.l3160&mkcid=7&ch=osgood&euid=b6273a9b202b4b46a54c0fa67ea4efac&bu=43581833467&ut=RU&exe=0&ext=0&osub=-1%7E1&crd=20230524063903&segname=11021
Is it me...or are the rear links bent!
Definitely bent, and both look to be bent to the same angle.
It can happen if you jack the car up under the bottom links, but being the same bend each side looks to be deliberate, too much of a co-incidence.
Offline Vegantune
  • 47+ Years Europa TCS /JPS Owner/Fixer/Improver
Re: Another Ebay TC
« Reply #5 on: Friday,May 26, 2023, 06:22:08 AM »
Picture a Europa with intentionally bent rear lower links . . . .
- A Norwegian Blue with beautiful plumage is still nothing but a dead parrot.
1973 Black Europa TCS/Vegantune JPS #180
1973 White Europa TCS
2012 Jaguar XJL 5.0 Supercharged
1975 Ferrari Dino 308 GT4
1994 Volvo 940 Shoebox Wagon
2005 Yamaha V Star
1998 Kawasaki XII Voyager
Re: Another Ebay TC
« Reply #7 on: Sunday,May 28, 2023, 06:13:01 AM »
There are shop lifts, designed for solid axle cars, that will bend Europa rear links every time.  My first shop where I apprenticed had one as did one of the the body shops my Europa went to.  I stopped by for a visit, saw the Europa on the lift, saw the now bent links, and didn’t bother to say anything.  Too late now and when were they ever going to work on another?
https://www.k-bid.com/auction/12543/item/4
Offline Vegantune
Re: Another Ebay TC
« Reply #8 on: Saturday,June 10, 2023, 04:48:52 PM »
Reposted a couple of days ago with same starting bid of $20,625 w/reserve.
https://www.ebay.com/itm/385671925772
2005 Yamaha V Star
Offline Arizona
Re: Another Ebay TC
« Reply #9 on: Sunday,June 11, 2023, 06:57:01 AM »
That likely explains why my links had a slight bend when I acquired the car. Probably happened when the PO had the tires rotated; 185's to the front, 175's to the rear. I replaced the links with adjustable ones from TLC.
George F. Johnson
