Author Topic: Assembly question…oil pressure gauge line and speedo cable  (Read 387 times)
« on: Sunday,May 21, 2023, 06:22:39 AM »
Do I need to install the oil pressure gauge line and Speedo cable prior to lowering the body onto the chassis? Or can just run some string through the chassis to facilitate installation after lowering the body (I am concerned about messing them up…)?
Re: Assembly question…oil pressure gauge line and speedo cable
« Reply #1 on: Sunday,May 21, 2023, 06:25:53 AM »
Both are easy enough to feed through after the chassis is attached to the body.
« Reply #2 on: Sunday,May 21, 2023, 10:38:33 AM »
Thanx!
