Author Topic: S2 stock starter removal?  (Read 280 times)
« on: Tuesday,May 16, 2023, 07:30:44 PM »
Search let me down, no result at all.
When I took the starter out of an R16 is was barely do-able, after dropping the down pipe.
S2 does not look any easier.
Do they come out, or do I have to partially remove the engine?
Starter cranks but squeals.  :-X
Re: S2 stock starter removal?
« Reply #1 on: Tuesday,May 16, 2023, 07:49:13 PM »
  Hi Richard,  I broke down and purchased the gear reduction type unit from RD.  The original starters, reported by other members were troublesome and slow cranking.
  I can’t help with the removal info but it does seem tight, but can’t imagine having to pull engine to remove.
  I just checked the manual here, no on the engine removal 😆
     http://www.lotuseuropa.org/images/WorkshopManual/S2_Section_M_-_Electrical_Equipment.pdf
« Reply #2 on: Tuesday,May 16, 2023, 07:54:32 PM »
I looked at the starter and manual but remain skeptical.
Leaving it in for tonight, I put some oil down the cylinders to ensure they are not dry.
I will try it again in the morning and pull the starter if I must.
« Reply #3 on: Wednesday,May 17, 2023, 05:51:53 AM »
Due to the tight quarters in a Renault powered Europa, the original starter is smaller than ideal.  It’s a wiggle to get it in and out.  You may have to remove/loosen after-market headers.  The gear-reduction starters are easier to fit and perform better.
« Reply #4 on: Wednesday,May 17, 2023, 06:01:18 AM »
Taxing the old noodle now but if I recall, it was a right fiddle.
I think I ended up taking off the engine mount but it might have come out without that. It's heavy in that awkward spot so I figured that would be the fastest way.
« Reply #5 on: Wednesday,May 17, 2023, 06:17:46 AM »
I recall replacing the stock starter with a gear reduction one from RDE. Removal was a bitch, essentially wiggle, twist, wiggle until at a certain position the starter cleared the obstruction, totally impossible to describe in writing. I don't believe I had to remove any components.
« Reply #6 on: Wednesday,May 17, 2023, 08:11:43 PM »
And the answer is.......
Not happening without removing the exhaust clamp, moving the pipe, and lifting the engine just a little.
Maybe with brand new mounts the engine would not have to be lifted?
Hi-Torque goes in and out easily.
