Author Topic: DIY Rebuild: Europa TCS Lucas Ignition Switch  (Read 622 times)
Offline FourLoti
« on: Monday,May 08, 2023, 09:12:30 AM »
Hi: In addition to getting the door open (see other thread) my first objective was to hook up a battery and see how bad things were electrically. Good news, there was no smoke, bad news, there was nothing else either. Traced +12 to the ignition switch but nothing was coming out in any key position. So, it looked like that would be my first parts order. But then figuring I had nothing to loose (except small springs, etc.) I decided to pop it open to see what could be accomplished. Turns out, a lot and I'm happy to report all circuits are up and running, including solenoid and starter!
I've been away from British forums for some time, and imagine that restoring these types of switches may have been written up elsewhere, but I found a little trick and thought I'd share for future reference.
1) Put the body lightly in a vise and tap out the edge crimps with a small screw driver and hammer. Photo 1
2) Once loose, the back of the unit (with lugs) will rise up about an 1/8 of an inch due to internal springs. Make sure the unit is facing up so nothing falls out.
3) The guts consist of several layers that all come out one at a time.  Photo 2.
4) I didn't get a "before" photo, but as suspected, all contacts were messed up with a combination of solidified grease, green corrosion and a few burnt spots to boot. Cleaning and polishing results are in Photo 3.
5) Now, how to reassemble? The white "body" goes in first, but there is a catch in that the detent function happens between this part and the bottom of the case. In Photo 4, you can see the detent spring in it's hole, and the ball bearing in the the most clockwise dimple (Key Off position) A dab of grease will keep these both in place.
6) So you have to orient the white body so that when you insert it, the spring in hole covers the ball bearing. This means the white body won't fully seat unless you apply pressure to compress the spring. Not that hard to do after some practice, but then what? You still have three more layers (and more springs) to pile on top and I had no luck doing this without the detent arrangement losing position.
7) I figured the factory must have had some sort of fixture and then it occurred to me that what was needed was a hands-free way to keep the white body in place. And since this part is exposed at both ends of the unit, it looked possible to drill a hole through it and use a long, thin screw and nut as an internal "clamp" This also provided a convenient handle to put in the vise during the remainder of assembly Photo 5.
8 - The sequence now was to replace the three springs (taken out early on to prevent losing them) Then the 3-contact brass rotor, which just floats on the three springs. Next comes the slotted insulator and finally the back cover with lugs. Oh, and a good amount of dielectric grease along the way.
9) Due to the three springs, it's still a bit tricky to line up all the layers over the center of the white body, but without too many tries I was able to get to where I could push down on the back cover and get it to fully seat in the case. A helper came in handy to maintain pressure with an open pair of pliers while I tapped the crimps back in place.
And that was it. It probably wont last for another 50 years, but then again, I'm not exactly going to be giving it much of a workout anytime soon. :)
Ron
« Last Edit: Monday,May 08, 2023, 10:09:30 AM by FourLoti »
1974 TVR 2500M
1987 Esprit Turbo (gone)
1980 Eclat (gone)
1963 Elan S1 (gone)
1970 Europa S2 (gone)
Re: DIY Rebuild: Europa TCS Lucas Ignition Switch
« Reply #1 on: Monday,May 08, 2023, 09:26:28 AM »
Nice!
« Reply #2 on: Monday,May 08, 2023, 10:03:45 AM »
Nice write up! I hope I won't need it but if I do, I hope I can find it again!  ;D
Maybe you could put a copy of it in the "Technical Articles and DIY tools and tips" section. It might be easier to find it later.
« Reply #3 on: Monday,May 08, 2023, 11:23:16 AM »
Noticed some pitting in the copper that may come back to bite you.  You can repair the contact surfaces with a careful application of silver solder (not the plumbing stuff).
« Reply #4 on: Monday,May 08, 2023, 12:36:56 PM »
  I just purchased the switch from moss motors complete with a set of keys.
I’ll post pics of the pn Later . Search Triumph spitfire .
« Reply #5 on: Monday,May 08, 2023, 04:04:18 PM »
Yes, new switches as inexpensive and you can fit the original tumbler.
« Reply #6 on: Monday,May 08, 2023, 04:37:32 PM »
Here is the link I was looking for ,
http://www.lotuseuropa.org/LotusForum/index.php?topic=2058.1800
