Author Topic: 395 shift linkage, what are you using  (Read 600 times)
« on: Wednesday,May 03, 2023, 11:27:27 AM »
For those with the 395 conversion, can you post some pictures of your shifting method. I'm assuming a cable system will be required.
I'm asking this for a friend of mine doing a Zetec conversion with a 395 transaxle on his Europa.
Re: 395 shift linkage, what are you using
« Reply #1 on: Wednesday,May 03, 2023, 07:59:20 PM »
I let Toyota design and build the cable shifter unit:
I removed the metal bracket and mounted the plastic part inside the chassis (shows reverse lock out as well):
I anchored the custom cables in the rear chassis diaphragm:
Cable runs and rear anchors:
Fore and aft directly to the transaxle selector:
Side to side through a motion reduction lever:
It all worked beautifully:
« Last Edit: Wednesday,May 03, 2023, 08:02:44 PM by jbcollier »
« Reply #2 on: Thursday,May 04, 2023, 04:43:35 AM »
The pictures are much appreciated. Did you modify the rear trans hoop or replace it? My friend has a S2.
« Reply #3 on: Thursday,May 04, 2023, 06:04:31 AM »
I made up a new rear trans loop.  Was a while ago and I can't remember exactly why (insert sheepish grin).
Offline TVrebel
« Reply #4 on: Monday,July 31, 2023, 03:09:06 PM »
Does anyone have a drawing or schematic of the linkage for a Renault 395 transaxle.
Thanks
william.enzweiler@gmail.com
Offline TVrebel
« Reply #5 on: Monday,July 31, 2023, 03:20:56 PM »
Let me explain, I'm not sure where the leavers (on the 395) need to be for 1st, 2nd, 3rd, 4th 5th and R.
Thanks
« Reply #6 on: Tuesday,August 01, 2023, 08:01:43 AM »
William, I 'm not understanding what you are asking. Are you talking about the position of the shift shaft at the rear of the 395 and their relative position for each gear selection or are you asking about a non cable shifter i.e. rod type shifter.
« Reply #7 on: Tuesday,August 01, 2023, 11:51:37 AM »
Looking at the rear of a 395 with the input shaft end facing away from you.  This puts the shift lever on your right side:
Rod all the way in (farthest left) and lever pushed back = 5th gear
Rod all the way out (farthest right) and lever pushed forward = reverse
The rest you can sort from there.
