Author Topic: Cable etc routing through rear frame bulkhead  (Read 250 times)
« on: Friday,April 21, 2023, 12:19:26 PM »
Is there a diagram that shows which cable etc goes through which hole in the frame bulkhead before the “Y” section ?
Should have taken even more pictures ???
Re: Cable etc routing through rear frame bulkhead
« Reply #1 on: Friday,April 21, 2023, 02:06:49 PM »
« Reply #2 on: Friday,April 21, 2023, 06:28:10 PM »
Thanks JB, does oil pressure gauge hose go through the same hole as the speedometer cable?
« Reply #3 on: Friday,April 21, 2023, 11:03:44 PM »
I believe there are also the choke and heater cables to consider too...
« Reply #4 on: Saturday,April 22, 2023, 03:06:54 AM »
True…..anyone have a pic?
« Reply #5 on: Saturday,April 22, 2023, 04:15:54 AM »
Choke and heater cables run on top off the chassis in an S1/2.
