Author Topic: Lost some weight this winter  (Read 663 times)
Offline cazman
« on: Sunday,April 16, 2023, 03:45:35 PM »
Upgrades and some weight loss.
1973 Europa TCS
Re: Lost some weight this winter
« Reply #1 on: Sunday,April 16, 2023, 04:30:59 PM »
 :beerchug:   :pirate:   :BEER3:
« Reply #2 on: Sunday,April 16, 2023, 04:42:23 PM »
Manual window pull-up conversion?
I've wondered if a system as used for Abarth racers might work.
Basically a wing nut, clamp, and single post.
Offline cazman
« Reply #3 on: Sunday,April 16, 2023, 05:27:23 PM »
I struggled with my window for too long. I took the frame apart twice and it still binds up. The straps were easy and I can always go back. Interestingly, the plastic nut insert that is used for license plates fits very well into the track at the bottom of the window to attach a strap to.
1973 Europa TCS
« Reply #4 on: Sunday,April 16, 2023, 06:17:50 PM »
Nice! Did you weigh the parts you removed?
Offline gideon
« Reply #5 on: Sunday,April 16, 2023, 06:57:07 PM »
How easy are the window straps to use?  Do they close tight?  Any rattles when you go over a bump?
Offline cazman
« Reply #6 on: Monday,April 17, 2023, 04:03:08 AM »
I find the straps easy to use. The window is either up or down and only moves a few inches between.
I put a rubber grommet in the strap, so there is a little cushion. They have not rattled.
1973 Europa TCS
« Reply #7 on: Monday,April 17, 2023, 05:29:12 AM »
You didn't like the konis?
Offline cazman
« Reply #8 on: Monday,April 17, 2023, 05:46:11 AM »
LOL. Yes, I did. I will keep them to go back some day, but for the track I needed something a bit stiffer.
Your Konis were good for me to put the car back to stock to see what the baseline is supposed be, because the set up before was not optimal.
I was surprised on how light the Pro Techs are compared to those.
1973 Europa TCS
« Reply #9 on: Monday,April 17, 2023, 06:44:03 AM »
Very cool! I'm digging the window mod. Been thinking of something similar myself.
Offline cazman
« Reply #10 on: Saturday,April 29, 2023, 07:01:02 AM »
I did not weigh the parts I removed, but the total weight of the car is 1,550
1973 Europa TCS
