Author Topic: S1 Front Sway Bar  (Read 413 times)
Offline My S1
S1 Front Sway Bar
« on: Sunday,April 09, 2023, 05:34:16 PM »
There is virtually zero clearance between my front sway bar and the belly pan.  Is this the normal situation?  Does it open up once it is on the ground?
Re: S1 Front Sway Bar
« Reply #1 on: Wednesday,April 12, 2023, 06:41:32 AM »
Hmm, here a photo of mine while the car is on the ground:
« Reply #2 on: Wednesday,April 12, 2023, 06:42:15 AM »
Has your chassis been changed?
Offline My S1
« Reply #3 on: Wednesday,April 12, 2023, 07:45:22 AM »
Original chassis.  I can not see from your photo but it appears as though your sway bar is flush up against the belly as well, no?
« Reply #4 on: Wednesday,April 12, 2023, 10:29:52 AM »
Nope, lots of clearance.  here's a couple more photos:
« Reply #5 on: Wednesday,April 12, 2023, 10:30:39 AM »
What have you done to it?  Was it fine before?
Offline Hachille
« Reply #6 on: Wednesday,April 12, 2023, 10:39:37 AM »
Good morning,
Difficult to see well in the photos. I took some photos yesterday.
I realize that I have touched speed bumps.
We probably have the tallest in the world in France. ;)
Offline My S1
« Reply #7 on: Wednesday,April 12, 2023, 11:04:00 AM »
Thank you Hachille & John.  I might have a serious mismaladjustment here.  When I get my wheels back from the restorer and get the car back down on the ground I'll see where it ends up in driving position.  If there is still no clearance I'll either cut the drop links and lengthen them or do what Pfreen did and add some heim joints.  Thanks for the pix.
« Reply #8 on: Wednesday,April 12, 2023, 12:06:52 PM »
Did someone shorten the links to keep from dragging on the ground?
« Reply #9 on: Wednesday,April 12, 2023, 10:13:00 PM »
It does look close but I'm not sure how much difference it makes as long as it's not rubbing on anything else. When you get the car sitting on it's wheels, as long as the ends of the bar meet the damper mounting pin squarely and without distorting the rubber bushes there (no preloading) then I think I'd just leave it alone.
I made my links adjustable to go with lowering the suspension, maybe someone did the same on the car ?
Offline My S1
« Reply #10 on: Thursday,April 13, 2023, 08:59:41 AM »
With further research it seems as though the lengths of the drop links were lengthen by the factory over the years.  Mine measure 11-1/2" overall with a part number 0f 46-C-005 but Ray at R.D. has a set measuring 12" overall with a part number of 54-C-005.
I can see how the length of the drop link will in fact effect the ride height up front.
« Reply #11 on: Thursday,April 13, 2023, 03:31:05 PM »
Drop link length only affects the position of the sway bar.  It does not affect ride height.
