First order of business was to remove all the dead leaves and rat dung from the engine compartment, frunk was not so bad, no vents.
Why are cars always parked under trees?
Next was removing the rear deck lid for repair.
Somewhere along the way one of the "Pro" car movers had to have leaned it up against the back of the roof, in the wind.
Confirmed by the location of the break.
Also cracked along almost the entire length of both sides at the corner line.
So this will be a chore but maybe stronger than original when I am done.
I think I will also add some sort of limit straps to prevent it happening again.
Seems there should be a prop-rod from the factory.
