Author Topic: 336 Gearbox Clutch Problems  (Read 731 times)
Offline DreamsOfA47
Re: 336 Gearbox Clutch Problems
« Reply #15 on: Friday,March 03, 2023, 09:50:39 AM »
Thanks, Y'all!
Turbo the bolt is tight in the end of the shaft so it rotates with the pedal as its depressed and released.
I'm thinking of maybe adding a flat U-bolt and passing it over the pedal shafts and through the floor reinforced by a metal plate somewhere inboard of the brake pedal for added strength and retention.
« Last Edit: Friday,March 03, 2023, 09:52:47 AM by DreamsOfA47 »
