Hello all,
I have a very vexing issue with my clutch. When I depress the clutch pedal the pedal doesn't come back up off the floor. While the pedal is on the floor, the clutch assembly is disengaged from the engine and the car is in neutral. Upon releasing the pedal it comes up about 80% of the way and then stops. Frustratingly the last bit of throw is the bit that allows for the engagement of the gearbox. The only way to get the last bit of throw is to pull the pedal back with my toes. This means the car can't be put into gear without physically pulling the pedal back after the pedal has been depressed. I've replaced the clutch disc, pressure plate, T/O bearing and clutch cable and I've greased all the fittings and shafts and cables and joints and everything I can think of. I've also greased the T/O bearing as described in the manual and I'm at a loss for what to do now. Any advice from y'all who know more? I've also ensured that my clutch cable is properly seated in both the front and rear cable abutments and has been properly affixed and tightened to the clutch arm.
You may have read this problem expressed in my build thread, but I thought I'd start a dedicated thread for those who maybe haven't seen my build but have good input or experience with a similar issue. I apologize if I'm
but I'm supremely vexed! I'm truly stumped as to what may be the issue. I'm hoping to drive the car to a mid-engine themed cars and coffee on March 11th. That may not be possible but I'm trying desperately to get this car sorted.
So, y'all any ideas?
