Author Topic: S1 FUEL SENDER MODIFIED FROM S2 SENDER  (Read 420 times)
Offline My S1
« on: Wednesday,February 22, 2023, 04:27:20 PM »
I was only able to locate and purchase an S1 Fuel Sender so I spent quite a bit of time (retired...) calculating and modifying an S2 Sender.  Hopefully these diagrams will save another S1 owner, with an original tank, some hours of figuring.
Offline My S1
Re: S1 FUEL SENDER MODIFIED FROM S2 SENDER
« Reply #1 on: Wednesday,February 22, 2023, 04:28:57 PM »
Pictures attached;
Offline My S1
« Reply #2 on: Wednesday,February 22, 2023, 04:30:09 PM »
Sorry...can't figure how to add multiple pictures at once
Offline My S1
« Reply #3 on: Wednesday,February 22, 2023, 04:31:06 PM »
More pix;
Offline My S1
« Reply #4 on: Wednesday,February 22, 2023, 04:31:46 PM »
last one...I promise
Offline My S1
« Reply #5 on: Wednesday,February 22, 2023, 04:39:01 PM »
Forgot to mention, the S2 sender from R.D. was so long that I first cut about an inch off the end of the arm then re-bent a new loop to retain the float.
« Reply #6 on: Wednesday,February 22, 2023, 07:54:37 PM »
At the back of the gauge are one or two adjustable spring anchors.  Turning them will change the gauges sweep range and rate.  You should be able to fine tune it so it more accurate reads the tanks contents.
