Super cool. I know how much research, thought and work goes into something so far from stock.
I know you probably want to work that external WG in somewhere but for what it's worth, the 4.0 Ford Barra's use a GT3582 with internal gate. I'm running a GTX3584 with a Barra style internal wastegate housing to keep the plumbing simple. The 3584mm is worth a few more HP over the 82. The Barra housing won't work with the larger GTX turbine though, have to use the standard GT35.
Is it going to be road legal too?
What EFI? I know some have TC, are you planning on running it?
You said measured to order wheels. That diameter and width and tires?
Looking forward to any pics you post.
I love the Barra, I am an Aussie
Actually the solution to WG problem is an Aussie one, a number of the Barra boys are welding the WG tube into the scroll of the hot side, this is a good option as it provides a better flow path into the WG pipe, only problem is finding a turbo blanket to fit around the WG pipe. I am probably going to run the turbosmart straight through electronic wastegate for ultimate control.
Yes the car will be road "legal"ish as I have the UK reg papers for the car and should be able to get it registered under the classic reg that does not require and MOT now in the UK. If I get that before taking to Jersey should be ok.
EFI is the Megasquirt Pro unit, I used these units on many applications over the last 15 years, so its what I know well and they are damn capable and super cheap v their functionality
https://www.diyautotune.com/product/ms3pro-ultimate-standalone-engine-management-system/My rear hubs and CV are Audi to match the 01E transaxle and have a trigger wheel on the them so if I fit a hall effect sensor I could run TC, but probably not going to. The solution (and I might be dreaming) is lots of rubber and light vehicle weight and the trick wavetrack LSD.
Wheels are 12 x 15" rear and 10 x 15" fronts which will let me run some series rubber. Front Avons are 255 and rear 325 tread width.
https://www.imagewheels.co.uk/p917-alloy-wheel/. These are the biggest I could fit while maintaining space between the frame and wheel for the underbody aero.
(Thought I would add some example pics of hot side housings with external WG ports , so show what I plan to do )
