Author Topic: WTB: Banks Europa Frame/ Roller  (Read 6746 times)
Offline surypap3
« on: Wednesday,February 15, 2023, 08:49:30 AM »
Looking for a Banks chassis for additional strength. Does anyone have a project car/ roller/ Banks chassis/ running gear for sale. Jack 703-474-6490
Offline gideon
Re: WTB: Banks Europa Frame/ Roller
« Reply #1 on: Wednesday,February 15, 2023, 09:31:27 AM »
Is a Spyder frame not strong enough for you?  I'm just curious.
Offline surypap3
« Reply #2 on: Saturday,March 11, 2023, 12:53:22 PM »
That's a good question. First the spider frame .... is that what they call the OEM Europa frame? Secondly, I just assumed if you were to put say 250 hp back there that it may be too much for the OEM frame. Totally willing to be educated on this. What are your thoughts? Thank you!
Jack
« Reply #3 on: Saturday,March 11, 2023, 01:04:29 PM »
Spider (Spyder?) is a separate company that makes a much better frame than OEM.
« Reply #4 on: Saturday,March 11, 2023, 01:16:47 PM »
Jack
From the rear firewall forward on mine is stock frame. 450hp and at least 350 tq. I beat on it and autocross it with wide soft tires. No problems yet. I know the Tee area in the front can crack and I'm sure mine will.
It's not the HP but torque that kills things.
Offline surypap3
« Reply #6 on: Saturday,March 11, 2023, 02:17:42 PM »
So what did you do to the frame from the firewall back and can you tell me about your drivetrain mods ..... engine, transaxle and out to the wheels. Thx
« Reply #7 on: Saturday,March 11, 2023, 05:38:04 PM »
It is something that I would not do again so it isn't a I did it to make it better.  To do again, I would leave the frame as is and I would use an Audi or Boxster trans and run it longitudinally and not cut the frame. What I did took wayyy too long to do and then I had to design the suspension to work with the short arm length I was stuck with using.
250 hp isn't too much. A turbo 4 age could do it and fit in the frame. Ford Zetecs fit and a few psi would easily do 250+ too. There are lighter engines though. If you have a frame I would use what you have.
Engine is a Toyota 2GR 3.5 V6 Turbo GT3584 8 psi
Trans is an E153 trans with taller FD and LSD.
Camry ouiter/MR2 T inner axles
AW11 MR2 rear hubs with SLA rear suspension
Custom brakes
« Reply #8 on: Saturday,March 11, 2023, 05:40:12 PM »
A few more
Offline surypap3
« Reply #9 on: Sunday,March 12, 2023, 03:37:38 PM »
Looks nicely done, and like you said, a fair amount of engineering went into it. I like the notion of a zetec. I know there are many examples of this. Would the Audi or Boxter transaxles boly up/fit easily? What other lighter engines were you thinking about? Thx
« Reply #10 on: Sunday,March 12, 2023, 03:38:51 PM »
Kennedy Engineering makes adapters for both.
Offline surypap3
« Reply #11 on: Sunday,March 12, 2023, 04:07:42 PM »
Thank you
« Reply #12 on: Sunday,March 12, 2023, 04:59:02 PM »
I believe the Zetec bolts to the twin cam 5 speed as well. There are a few on this forum. PM them and ask details. Check the facebook group too.
Offline RoddyMac
« Reply #13 on: Monday,March 13, 2023, 07:15:24 AM »
The Zetec does indeed bolt to the Twin Cam bellhousing, which means you can fit an NG3 5 speed with a little bit of modification.
Offline surypap3
« Reply #14 on: Tuesday,March 14, 2023, 04:08:13 PM »
Very nicely done! Now is that a Zetec with an NG3? I don't suppose you can slip an AC compressor in there somewhere? The front half of the frame is the stock chassis with reinforcement? How much HP can a Zetec put out? 250+ naturally aspirated?
