Author Topic: Wheel Nuts  (Read 1688 times)
Offline wilkrod
Wheel Nuts
« on: Monday,February 13, 2023, 10:11:42 AM »
Hi All,
Just recently discovered that my wheel nuts are different.
Anyone know why?
Which is correct?
Many thanks.
Jeff
2021 Evora GT
1886 Turbo Esprit HCI
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
2022 Infiniti Q60 (Wife's)
2022 Hyundai Santa Cruz
Online Kendo
Re: Wheel Nuts
« Reply #1 on: Monday,February 13, 2023, 10:25:04 AM »
Are these for the Brand Lotus wheels?
The set I have for Brand Lotus look more like the right one.
Re: Wheel Nuts
« Reply #2 on: Monday,February 13, 2023, 10:26:38 AM »
+1 on Kendo, What wheels do you have?
Regardless of the nut, you do have washers for them, right?
Offline wilkrod
Re: Wheel Nuts
« Reply #3 on: Monday,February 13, 2023, 10:33:30 AM »
Guys,
Thanks for the response.
Yes, Lotus wheels, and yes correct washer for them.
I am baffled why they would have different length shanks.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Re: Wheel Nuts
« Reply #4 on: Monday,February 13, 2023, 10:36:24 AM »
Someone lost one and found a replacement that would work.  A lot happens in 50 years.
Re: Wheel Nuts
« Reply #5 on: Monday,February 13, 2023, 11:46:13 AM »
r.d. makes stainless steel reproductions. There may be other reproductions too and they may be a little different.
Re: Wheel Nuts
« Reply #6 on: Monday,February 13, 2023, 12:39:28 PM »
My originals are like the one on the right in your pic.
Offline wilkrod
Re: Wheel Nuts
« Reply #7 on: Tuesday,February 14, 2023, 06:23:07 AM »
Just an update.
I inspected all the wheel nuts, half are the long shank, half short shank.
The short shank nuts will not always torque to 40 ft/lb.
The long shank nuts will
The rear axle has new studs on both sides, no striped threads.
Total confusion.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Re: Wheel Nuts
« Reply #8 on: Tuesday,February 14, 2023, 06:30:06 AM »
The short shank bolts will not torque to 40 ft/lbs because...
Are their threads stripped?
AFAIK, the correct torque is 45 ft/lbs.
Offline wilkrod
Re: Wheel Nuts
« Reply #9 on: Tuesday,February 14, 2023, 07:12:17 AM »
I inspected all the threads, cleaned them, none are stripped, studs, and nuts. Thread chaser goes easily in all nuts/bolts.
My owners manual, states 40-45 ft/lbs.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Re: Wheel Nuts
« Reply #10 on: Tuesday,February 14, 2023, 07:33:16 AM »
What happens when they won't torque to 40 ft/lbs.
Re: Wheel Nuts
« Reply #11 on: Tuesday,February 14, 2023, 10:03:23 AM »
The nuts on the rear of mine stripped when I tried to torque them to 40.  The studs don't stick as far out of the wheels on the rear, I assume it's because of the thickness of the drums.  I replaced all mine with longer shank versions.
Offline wilkrod
Re: Wheel Nuts
« Reply #12 on: Tuesday,February 14, 2023, 10:12:54 AM »
When trying to torque the short shank bolts, I can feel it taking less torque to turn the nut, so I stop. I then install one of the long shank nuts, it torques fine.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Offline wilkrod
Re: Wheel Nuts
« Reply #13 on: Tuesday,February 14, 2023, 10:15:12 AM »
Now thats interesting because I have a 50/50 split of long/short shanks. I took all four wheels off at the same time, and just dumped the nuts in a bag. I believe I will look at the front vs. rear, and see if I put all the long shanks on the back the issue is resolved. Thanks for the input!
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Offline My S1
Re: Wheel Nuts
« Reply #14 on: Tuesday,February 14, 2023, 10:24:22 AM »
While on the subject of nuts...what is the correct torque for the old stamped steel S1/S2 rims?
