Author Topic: Pedal assembly drawing?  (Read 943 times)
« on: Thursday,February 02, 2023, 01:15:30 PM »
Is there a drawing with dimensions of the pedal assembly available?
Re: Pedal assembly drawing?
« Reply #1 on: Thursday,February 02, 2023, 01:38:30 PM »
I found a drawing for dual M/Cs that you should be able to adapt here: https://drive.google.com/drive/folders/1RE6xKmBQ1UNNfADyDYKkhPpZwlese3Oa
I think JB fab'ed his own pedals and might have some drawings.
« Reply #2 on: Thursday,February 02, 2023, 01:52:00 PM »
Thanks BDA!
Offline Dilkris
« Reply #3 on: Friday,February 03, 2023, 02:50:17 AM »
TurboFource,
Please find attached - note, these are not my drawings - I filed them away some time back when I came across them.
« Reply #4 on: Saturday,February 04, 2023, 11:47:58 AM »
Has anyone fabricated a set of pedals from these drawings?
I seriously question the ability of an 1/8" spiral pin being able to handle forces
of a clutch long term..... :o
« Reply #5 on: Saturday,February 04, 2023, 08:20:19 PM »
Agreed, an 1/8" pin is too small for my comfort zone. If we're to adhere to the 1/3 diameter as the rule of thumb, that still only permits a ~ 4mm pin. Maybe make that lever arm wider and use 2 x 4mm pins - one on each side?
I'd seriously consider just welding it on. With the inclusion of a couple of grease nipples, it'll last another 50 years.
Anyone know who did the drawing?
Hang on . . the drawing calls out a 1/2" inner shaft??
Is that as per stock on the TCS? I ask because my S2 uses a 3/4" OD hollow shaft.
« Last Edit: Saturday,February 04, 2023, 08:54:37 PM by GavinT »
« Reply #6 on: Sunday,February 05, 2023, 04:50:21 AM »
I am using a 3/4” shaft and I have decided to weld the arm on.
I will also provide a way to lubricate the oilite bushings I am using.
Offline Dilkris
« Reply #7 on: Monday,February 06, 2023, 03:18:16 AM »
......Anyone know who did the drawing?
Whoever it was - he or she wasn't in the UK....   :))
« Reply #8 on: Monday,February 06, 2023, 01:58:08 PM »
Anyone using something other than rubber pads on their pedals?
« Reply #9 on: Tuesday,February 07, 2023, 05:34:55 PM »
Not me but I've seen some with that expanded metal mesh edge welded to the pedals.
« Reply #10 on: Friday,February 17, 2023, 08:16:15 PM »
Found these old pics . .
