Author Topic: Distributor drive gear failure  (Read 1115 times)
Re: Distributor drive gear failure
« Reply #15 on: Sunday,December 25, 2022, 01:41:36 PM »
Thanks Gavin.  I knew we had gone through this before.  I searched and searched but couldn’t find it.
Offline Rainer
« Reply #16 on: Monday,December 26, 2022, 10:03:30 AM »
Thanks everyone,
I was a bit lazy today, but this info spares me the drive to the garage.
Regards
Rainer
Offline Rainer
« Reply #17 on: Saturday,January 21, 2023, 08:37:25 AM »
Just want to let you all know, the head is back on, this time with the tool.
But one thing remains you can insert the 123 ignition the wrong way.
In the correct position it just drops in the wrong position it goes in a bit tighter but without the need of any force.
I dug up my old distributor and tried the same, but there is no way you can insert this one the wrong way.
I think the problem is the slightly different shaft design and the very flexible coupling on the 123.
« Last Edit: Saturday,January 21, 2023, 08:39:50 AM by Rainer »
