Author Topic: Wheel stud knurl size?  (Read 891 times)
« on: Monday,December 05, 2022, 04:00:15 PM »
I want to install longer studs, what is the correct knurl size? Thanks!
Re: Wheel stud knurl size?
« Reply #1 on: Monday,December 05, 2022, 04:23:19 PM »
I would also go up a size (i.e. 14mm). IIRC, the holes for my old 3/8” studs were the same as needed for my 14mm studs but they might have needed to be opened up a little. I found this that might help: https://www.jalopyjournal.com/forum/threads/what-size-knurl.1145929/
« Reply #2 on: Monday,December 05, 2022, 07:28:05 PM »
Haven't measured them myself but according to this Kiwi site, the knurl is 13mm and the long Spitfire studs are 48mm compared to the stock 35mm.
Studs from a Freelander seem to be a common upgrade for longer and larger diameter studs but apparently some versions have a longer unthreaded section.
References:
https://www.classiccarparts.co.nz/index.php?route=product/product&product_id=1034
https://www.ebay.com.au/itm/225100633921?hash=item34690b1741:g:e8IAAOSwEzJbBEpL
https://sideways-technologies.co.uk/forums/index.php?/topic/9205-landrover-freelander-wheels-studs/
Offline Fotog
  • 72 Twin Cam
« Reply #3 on: Monday,December 05, 2022, 09:00:22 PM »
I went the Freelander stud route and am very satisfied.  I discussed it here:.
http://www.lotuseuropa.org/LotusForum/index.php?topic=3392.msg35448#msg35448
My post says I measured .520 inches.
Vince
« Reply #4 on: Tuesday,December 06, 2022, 12:43:10 PM »
Is there a source for the Freelander studs on this side of the pond? (USA)
Offline Fotog
  • 72 Twin Cam
« Reply #5 on: Tuesday,December 06, 2022, 01:41:28 PM »
I think so, but I'm out of town, and my records aren't as well organized as intended, so I'm not sure I can help you.  99% sure I bought them from a US source though.
-V
« Reply #7 on: Tuesday,December 06, 2022, 03:27:29 PM »
Thanks BDA!
« Reply #8 on: Tuesday,December 06, 2022, 06:08:54 PM »
Dang….they might not get here till next year. Going to see if NAPA can cross reference the part number tomorrow
and come up with something….
« Reply #9 on: Tuesday,December 06, 2022, 06:38:12 PM »
There are a few other suppliers on eBay. If those fail, NAPA will likely have what you need, especially if they don’t need to be called a Freelander part. Lastly, Amazon is a a possibility also.
I don’t think there’s anything magical about Freelander studs. Any 1/2”, 12mm, 14mm that is too long can be trimmed to length.
« Reply #10 on: Tuesday,December 06, 2022, 10:53:14 PM »
True, mine weren't specifically for the Freelander, they were generic parts fitted to several MG Rover cars. The part number I used was NAM8116 and I would expect most British car suppliers over there will have them. I used MGF wheel nuts with them because I liked the 2-part assembly with a loose cone that fitted into the wheel, but they are intended only for the MGF wheel, they won't fit on Cosmic alloys for example.
A point to consider is these studs have an unthreaded section so if you're on steel wheels they aren't going to work.
UK source - https://rimmerbros.com/Item--i-NAM8116
original posting  (a while ago now)  http://www.lotuseuropa.org/LotusForum/index.php?topic=219.msg1314#msg1314
« Reply #11 on: Wednesday,December 07, 2022, 12:45:21 PM »
No luck at NAPA...not for the length I want. Will probably order from Rimmer Bros as suggested by EuropaTC.
« Reply #12 on: Thursday,December 08, 2022, 04:51:16 AM »
$42.94 for 20 studs from Rimmer Bros. With “express” shipping  :) ….the shipping was more than the studs :(
« Reply #13 on: Thursday,December 08, 2022, 09:44:17 AM »
Sometimes makes you wish you lived over there, doesn't it? Imagine having access to the experts and the parts we need over here without having to ship things around the continental US....
« Reply #14 on: Thursday,December 08, 2022, 10:32:56 PM »
But you really wouldn't like our weather Bryan...   :)
