72 Twin Cam
Having more or less finished restoring my TC I'm in process of ironing out the more minor details.
The car has Dellorto carbs and I've been working on tuning them correctly. I can highly recommend 'How to Build & Power Tune weber & Dellorto carbs'
by Des Hammill, it's a very comprehensive guide.
The throttle cable is routed from beneath, it pulls the throttle arm lever down and works smoothly. I have fitted the standard return spring, but it feels too strong
making the pedal quite stiff and heavy. Maybe it's the wrong one, I heard that the Weber spring is stronger?
Regardless of that, does anyone know of an adjustable return spring/bracket set-up that will fit on top of the carbs? I want to stick with a single cable system.
Thanks, Raf.
