Author Topic: Renault engine "Tuning manual"?  (Read 2560 times)
« on: Saturday,November 05, 2022, 07:53:46 PM »
One of the great things about most British cars is that they have a Competition Tuning Manual available.
MG, Triumph, Jaguar, etc. all have them, sometimes as a chapter of the standard workbook.
I have not seen any mention of such for the Europa, and nothing at all for the Renault engines.
I know we have some members here who race the Renault engine cars.
So where should I be looking for a tuning manual for my TS headed Renault engine?
This comes to the fore as I've been looking at the prior mod to my oil pan.
Someone took the trouble to divide it and add a gated baffle.
But it does not look right to me.
What I see seems like it would only hav an effect on right turns.
Nothing for left turns or acceleration.
It is also closed off at the top, so there is no direct path for oil to drain into the left side of the baffle.
I have read that the aftermarket cast pans duplicate the Gordini baffling.
I have to charge my camera before I may post a pic.  :(
Re: Renault engine "Tuning manual"?
« Reply #1 on: Saturday,November 05, 2022, 11:45:51 PM »
Fair point – don't think I've seen one either. Perhaps that's because Renault Sport offered piston/liner kits and that seemed to satisfy most home gamers. The more advanced stuff was always going to be closely guarded by various racing teams, I expect.
Remember too, that while much of the reverence is ascribed to the "Gordini" name, the engine development of most worth was done later under the Alpine banner. There was also an entry level Formula France / Formula Renault open wheeler class in France back in the day.
Lots happens in France and elsewhere which goes unnoticed, likely due to the language barrier.
Below is a link to the sale of a 1975 Martini MK15 Formula Renault from way back in 2010.
Interesting to read through the history; many names we're familiar with are there.
https://www.bonhams.com/auctions/18296/lot/39/
« Reply #2 on: Sunday,November 06, 2022, 12:20:53 AM »
Seeing this, there should be a wealth of information available.
"Formula Renault in 1971, Martini quickly asserted its dominance in the category, winning the French championship for an amazing 16 years consecutively between 1975 and 1990."
So who has the old teams note books?
« Reply #3 on: Sunday,November 06, 2022, 06:20:28 AM »
Remember that engines tuned for racing make for poor street engines.
Lots of good tuning info at aussiefrogs.
Sal is the Renault crossflow tuning guru and you are already talking with him.
« Reply #4 on: Sunday,November 06, 2022, 06:24:05 AM »
Here’s one post:
https://www.aussiefrogs.com/forum/index.php?threads/807-competition-motor.89618/
The did very well but had to be rebuilt regularly as the crank developed cracks due to the high revs.  They subsequently detuned it somewhat for longer crank life.
« Reply #5 on: Sunday,November 06, 2022, 07:45:45 AM »
Not looking for a full race tune.
At the moment my focus is the oil pan and possible upgrades to oil flow.
A crank scraper seems likely to be worth the effort.
Offline SwiftDB4
« Reply #6 on: Sunday,November 06, 2022, 03:55:16 PM »
You may be overthinking the oil pan. I raced my S1 with 807G in SCCA many years ago. Ran 11" wide slicks. Did manage to spin a bearing with stock sheet metal pan (no baffles). Welded in a horizontal baffle, but no vertical ones or any gates. Never had oiling problems again. Assume you're not going to approach G levels of wide racing slicks.
Necessity of cooling the oil is another issue.
Offline SwiftDB4
« Reply #7 on: Sunday,November 06, 2022, 04:25:38 PM »
Here are the 807G spec sheets. Sorry about the quality, but they're circa 1970. Don't know how much they might help.
« Last Edit: Sunday,November 06, 2022, 04:28:22 PM by SwiftDB4 »
« Reply #8 on: Sunday,November 06, 2022, 10:38:47 PM »
Go the whole hog, Richard . . .  ;)
« Reply #9 on: Sunday,November 06, 2022, 11:19:39 PM »
One of the future projects is a dry-sump Alfa Romeo engine in a custom tube-frame Dio Tipo build.
Had to dry-sump for ground clearance as DOHC engines are TALL!
More complexity than I would want for the Europa street car.
« Reply #10 on: Wednesday,November 09, 2022, 04:57:28 PM »
I have been making notes from that old competition prep thread.
Too bad it ended without further updates.
One thing that really stands out is the comment about the followers coming to a stop against the cam base.
I do not have my cam at hand right now but I will look at that when I get it back from Delta Cams.
« Reply #11 on: Wednesday,November 09, 2022, 10:44:49 PM »
I think it's a genuine issue.
I acquired an F2 Renault cross flow engine eons ago and took it apart. Below is a couple of pics of the cam.
You can see that the cam had been machined with a view to avoid the problem but the machining didn't extend far enough towards the dizzy drive.
The red arrows point to the area where the periphery of the lifter dug into the heel of the cam on both sides.
While the lifter face is fairly broad, it still seems to be quite a substantial offset from the lobe.
I should measure the lifter offset one day.
« Reply #12 on: Wednesday,November 09, 2022, 11:01:46 PM »
I read in that old race prep thread that the lifters are off-set to the lobes which imparts spin on them.
The complaint was that bottoming on the cam halts spin and increases wear.
Good to see the pics you posted.
I have a lathe and vertical mill so should be able to make the necessary clearances.
« Reply #13 on: Friday,November 11, 2022, 12:17:41 AM »
Yes, I can see it interfering with lifter rotation.
What's left unsaid is how this likely impacted the initial valve clearance settings.
How deep is the scallop created by these lifters? . . 40 thou?  . . .  80 thou?
As we know, valve clearances are set when the cam lobe is at the heel position. At least two lifters on my F2 engine must have had clearances set while the lifter was resting on the then unworn area.
Imagine the first start up where the engine is supposedly taken to 4K RPM for 20 minutes as Frans suggests.
At some point later, the clearances are approaching ~60 thou or beyond. Cam lobes are then slamming into lifters flailing about because the lifter can't follow the ramp of the cam until the valve/spring becomes engaged. Not to mention the side loads as these scallops are being formed.
Dunno for sure but that's my guess as to why we see lobe damage nearer cam nose in that Aussiefrogs thread. Also notice that Frans has machined the undercut all the way up to the dizzy drive.
« Reply #14 on: Friday,November 11, 2022, 10:26:32 PM »
Confirmed today that my cam arrived safely.
Had a brief conversation with Delta cams and they are going to deal with the cam heel/follower issue.
They also suggested another possible durability treatment.
"WPC", http://wpctreatment.com/about.htm
This treatment is popular with the Ricer racer crowd.  ;)
