Author Topic: Throw out bearing  (Read 331 times)
Throw out bearing
« on: Thursday,November 03, 2022, 02:03:43 PM »
Is it difficult to press the throw out bearing on and off it's holder?
Re: Throw out bearing
« Reply #1 on: Thursday,November 03, 2022, 02:37:08 PM »
I don't remember having any problems with it. Why?
« Reply #2 on: Thursday,November 03, 2022, 03:26:46 PM »
You can it with a vise as long as you spread the load with a block of wood.
« Reply #3 on: Thursday,November 03, 2022, 06:05:24 PM »
Just wanted to know if it was easy to do
« Reply #4 on: Thursday,November 03, 2022, 07:24:28 PM »
Set the vise jaws so they support the bearing but not the carrier.  Drive the carrier off using wood or plastic driver and a hammer.  Put the new bearing in position using a block of wood between the bearing the vise jaw and push the bearing in place by tightening the vise.
Basically you are using the vise as a primitive press.
« Last Edit: Friday,November 04, 2022, 06:48:55 AM by jbcollier »
« Reply #5 on: Friday,November 04, 2022, 03:34:11 AM »
Thanks JB
Offline RafM
« Reply #6 on: Wednesday,November 09, 2022, 06:05:39 AM »
I used JBs method recently, it worked perfectly.
