Author Topic: Need help troubleshooting popping/clicking noises around driver rear wheel.  (Read 706 times)
Re: Need help troubleshooting popping/clicking noises around driver rear wheel.
« Reply #15 on: Wednesday,October 05, 2022, 05:46:31 PM »
Was your hub Loctite’ed? I’m not suggesting that not having Loctite on the splines on your hub is causing your problem but you should use the proper Loctite on your hubs.
Offline 69merc
« Reply #16 on: Wednesday,October 05, 2022, 06:07:30 PM »
Yes. Everything about the hub nut, hub, splines, spacer appeared ok.  I didn’t take the bearing housing apart, but the bearings are new.  I really didn’t think the issue was in there.  The more I thought about it (and like others suggested) the ujoint could make those noises and movements.
« Reply #17 on: Wednesday,October 05, 2022, 10:02:51 PM »
Great, glad you found it.
On the latest video, it looks like there's only two circlips on the inner UJ.
In fact, one of the caps appears to be proud of the yoke.
Perhaps I'm imagining things?
« Last Edit: Wednesday,October 05, 2022, 10:28:08 PM by GavinT »
« Reply #18 on: Wednesday,October 05, 2022, 10:18:22 PM »
Great news, and well done for the feedback on how it went. Whether I've made the right guess or not I always like to know what the solution was, that way we all learn.
Offline 69merc
« Reply #19 on: Thursday,October 06, 2022, 06:40:55 AM »
GavinT…..thanks for pointing that out.  I will give that u joint a closer look this evening. :beerchug:
Offline 69merc
« Reply #20 on: Thursday,October 06, 2022, 08:41:57 PM »
Happy to report that the inner u joint looks good ( has all the circlips in).  Luckily it was just an allusion in the video  :beerchug:
