Author Topic: BigValve style valve cover for TOYOTA 4AGE 16V engine  (Read 1496 times)
Offline ralf
Re: BigValve style valve cover for TOYOTA 4AGE 16V engine
« Reply #15 on: Friday,September 23, 2022, 08:57:30 AM »
With my small cheap milling mashine I cut the area where there is a waterplug at the 4AGE cylinderhead.
Offline ralf
« Reply #16 on: Friday,September 23, 2022, 08:59:56 AM »
The hole for the oil filler was cut, first with a circlesaw.
Offline ralf
« Reply #17 on: Friday,September 23, 2022, 09:01:31 AM »
The exact diameter was made with a boring head. Final the axial surface was cut.
Offline ralf
« Reply #18 on: Friday,September 23, 2022, 09:25:22 PM »
The pins which hold the filler cap were made of aluminium. They are screwed in and fixes with LOCTITE.
Offline ralf
« Reply #19 on: Friday,September 23, 2022, 09:27:01 PM »
The cover is made for the filler cap of the Lotus TC
Offline ralf
« Reply #20 on: Friday,September 23, 2022, 09:32:52 PM »
A fiend of mine who has a big milling mashine cut the planar surface of the cover and drilled the 8 bores.
My cover did not use a gasket. I will use silikone.
Next I make a light countersunk to the 8 bores and mesured the gap betwen the head anf the cover.
Offline ralf
« Reply #21 on: Friday,September 23, 2022, 09:36:06 PM »
To reduse the stress in the cover when tighten the 8 nuts holding the cover, I want a clearance between the countersunk of the bores and the struds of 0,05 to 0,1mm.
Offline ralf
« Reply #22 on: Saturday,September 24, 2022, 10:27:08 AM »
The cylinderhead and valvecover need an opening for the O-ring area of this bracket. because I dont have a big milling mashine I used a manual Hunger valveseatcutter. A guide was made to position the cutter in the center of the camshaft.
Offline ralf
« Reply #23 on: Saturday,September 24, 2022, 10:28:01 AM »
With he Hunger I cut the bore in the head and the cover fixed together.
Offline ralf
« Reply #24 on: Saturday,September 24, 2022, 10:38:00 AM »
Maybe the most complicated work was to mashine the radius which will seal the cover to the first bracket for the camshaft. Because I don't want to damage the front of the cover I could not use a milling mashine (I dont have somebody with a CNC Mashine). It was done by positioning a guide to the cover und use a homemade cuttingtool which is driven by a drilling mashine. Finaly I could do it with a clearance between cover and head of 0,05 to 0,1mm, which can easy sealed by silikon.
Offline ralf
« Reply #25 on: Saturday,September 24, 2022, 10:45:03 AM »
Before painting the cover with VHT Wrinkl Plus the cover was cleaned with aceton and some surfaces get masked.
Offline ralf
« Reply #26 on: Saturday,September 24, 2022, 10:47:09 AM »
After spraying the cover it was heated up in a oven at around 90°C.
Offline ralf
« Reply #27 on: Saturday,September 24, 2022, 10:49:21 AM »
Finaly some areas were sanded down to the aluminium to get the TC like design.
« Reply #28 on: Saturday,September 24, 2022, 12:47:02 PM »
Great stuff, ralf!!! Very neatly done! I'm anxious to hear about the rest of the car!
« Reply #29 on: Sunday,September 25, 2022, 08:42:03 PM »
Phew . . what an absolute over the top spectacular undertaking, Ralf.
Very well done.  8)
