Author Topic: alt pulley modification for TOYOTA 4AGE  (Read 1321 times)
Offline ralf
Re: alt pulley modification for TOYOTA 4AGE
« Reply #15 on: Wednesday,September 21, 2022, 09:12:01 PM »
At the outer side at the extension a rubber ring was mounted to prevent a oil leakage between the extension and the pulley. A seal is installed into the bracket.
Offline ralf
« Reply #16 on: Wednesday,September 21, 2022, 09:13:32 PM »
The rear opening for at the cylinderhead is closed by the bracket and sealed with silicone.
« Reply #17 on: Thursday,September 22, 2022, 03:28:39 AM »
 8)
« Reply #18 on: Thursday,September 22, 2022, 08:29:34 AM »
Stellar job, Ralf!  :beerchug:
Offline ralf
« Reply #19 on: Thursday,September 22, 2022, 09:20:12 AM »
Thanks,
the bracket is fitted with two bolts and one strud.
Offline ralf
« Reply #20 on: Thursday,September 22, 2022, 09:22:19 AM »
The pulley is axial fixed a 5/16UNF bolt and tangential with a M6 wormscrew.
Offline ralf
« Reply #21 on: Thursday,September 22, 2022, 09:23:49 AM »
This picture shows the drive of the pulley
Offline ralf
« Reply #22 on: Thursday,September 22, 2022, 09:28:17 AM »
To fix the alternator a spezial boltwas made. This is screwed thru the bellhousing and adapterplate.
The outside of the bolt has a 10mm cylindtical diameter and a inner  5/16UNF thread to fix the alternator.
Offline ralf
« Reply #23 on: Thursday,September 22, 2022, 09:30:10 AM »
The alternator is from a Citroen 2CV. The bracket to tighten the V-belt is still missing.
Offline ralf
« Reply #24 on: Tuesday,October 25, 2022, 10:55:10 AM »
Today I finished the bracket to tighten the V-belt.
« Reply #25 on: Tuesday,October 25, 2022, 11:48:18 AM »
Very nice! It looks like the inside of a watch!
« Reply #26 on: Tuesday,October 25, 2022, 12:06:20 PM »
 8)
« Reply #27 on: Wednesday,October 26, 2022, 09:56:38 AM »
Nice work. Very impressive craftsmanship.
