In December 1994 I made an accident. A Renault 19 hit my left front wheel when I slide with cold Yokohama A008 tires into an intersection.
I was lucky that I don't get hurt. If I would slide 1m more into the intersection the R19 would hit my door instead the front susspension.
Hi Ralf,
my name is Stefan and I'm also from Germany. It's very funnny that I seem to have ended up buying the damaged front section of your car in 2020. I purchased the light blue front and a rear section from a different car as a package, when I needed parts to repair my own car's rear end. At the end of last year, I sold the front to Austria to a hillclimb racer, who had a front crash on the passenger side. Your body, which was crashed in 1994 will get a second life in 2023
The rear, from which you took your new front, is still in my posession. I'll keep it in case, I'd have another crash. I didn't use it for my repair in 2020, because I was able to source another used body, which was already cut into seven pieces. I have six of them left, as well
