Author Topic: Lotus Europa Bastard from Germany  (Read 26306 times)
Offline ralf
« on: Tuesday,September 20, 2022, 09:28:47 PM »
Hello everybody,
thanks for let me join your Forum. My name is Ralf and I am from Germany (in the south, 20km east of Stutgart).
I bought my Europa 1982 when I was 19 years old.
Offline ralf
Re: Lotus Europa Bastard from Germany
« Reply #1 on: Tuesday,September 20, 2022, 09:40:25 PM »
The Europa was in a very bad condition. It take me about one year to make it ready to make some test rides. After this I don't work at the car for many years.
Then I bouht a Spyder chassis with rear susspention, fit a Renault 843 engine modified to Bosch K-Jetronic injection of the old Golf GTI, a aluminium rockcover I made myself and a 395 transmission. 1994 I get a registration for the car.
Offline ralf
« Reply #2 on: Tuesday,September 20, 2022, 09:50:28 PM »
In December 1994 I made an accident. A Renault 19 hit my left front wheel when I slide with cold Yokohama A008 tires into an intersection.
I was lucky that I don't get hurt. If I would slide 1m more into the intersection the R19 would hit my door instead the front susspension.
Offline ralf
« Reply #3 on: Tuesday,September 20, 2022, 09:54:58 PM »
2020 I started to repair my Europa.
« Reply #4 on: Wednesday,September 21, 2022, 03:30:08 AM »
« Reply #5 on: Wednesday,September 21, 2022, 05:05:10 AM »
  Welcome Ralf,
   That was some crack to the front section to repair.  We definitely have some die hard Europa fans here that share your enthusiasm.
 Thanks for saving a part of history even with your upgrades.
Offline ralf
« Reply #6 on: Sunday,September 25, 2022, 09:06:13 AM »
Thanks for the welcome,
to weld the frame of my Seven I bought an old bench from CEVETTE for only €200.-. When the seven frame was finished I repaired the chassis of the Europa before I sold the bench again. With the bench you can make quiet acurate messurments on the chassis.
At the left front of the Europa chassis I needed replace some parts.
Offline ralf
« Reply #7 on: Sunday,September 25, 2022, 09:10:23 AM »
When the welding was finished I brought the chassis to leach (sorry for my english. I get 'leach' from the google translater I hope its right).
« Reply #8 on: Sunday,September 25, 2022, 09:11:39 AM »
That was a nice setup!!
Offline ralf
« Reply #9 on: Sunday,September 25, 2022, 09:15:06 AM »
After leaching the chassis was powder coated in RAL 7046 which is similar, but by  far not exactly, the colour of the old Lotus chassis.
But the colour 'old battleship grey' was not available for the powder coating. To make work at the finished chassis easy I bought a cheap lifting platform for motorbikes.
« Reply #10 on: Sunday,September 25, 2022, 08:37:48 PM »
Maybe 'dipped' ?
Nice one - it looks like the chassis was dipped in an acid solution to remove rust and paint?
And I was Christened in Germany, but don't speak the language.
Obviously at that age, I probably wasn't speaking any language.  ;D
Offline ralf
« Reply #11 on: Sunday,September 25, 2022, 09:21:10 PM »
Thanks GavinT,
yes it was dipped in a solution of hot 'lye' (again a word I googled but don't know if it is right). With acid it is hard not bring away the coating, therefor lye can not bring away rust. But the chassis did not have any rust.
Offline ralf
« Reply #12 on: Monday,September 26, 2022, 08:54:55 PM »
The left front of the body was heavy damaged. So I bought a used body which the seller told me is in very good condition. But the rear was much worse than on my car.
Offline ralf
« Reply #13 on: Monday,September 26, 2022, 08:56:27 PM »
So I decied to use only the front of this body.
Offline ralf
« Reply #14 on: Monday,September 26, 2022, 08:58:00 PM »
At this front I removed the flashlight area.
