Author Topic: Do 821 and 807 Renault blocks use the same sleeves?  (Read 421 times)
« on: Friday,September 16, 2022, 09:54:23 PM »
I know I have seen the answer to this somewhere, probably here.
Not finding it tonight.
Re: Do 821 and 807 Renault blocks use the same sleeves?
« Reply #1 on: Saturday,September 17, 2022, 05:27:20 AM »
The 821 and 807 are basically the same block - both with 82.5mm base locating diameter for the sleeves and the same crank stroke and liner sealing arrangement (paper rings).
I expect the sleeves are the same.
« Reply #2 on: Saturday,September 17, 2022, 06:45:27 AM »
They are basically the same sleeves.  At manufacture, sleeves are matched to pistons and sold as a set.  If you are mixing and matching, check your piston clearances carefully!
The early 697 (1470 engines came with a 82mm base.
