Author Topic: Door Pin Bushing Removal  (Read 1666 times)
Offline cazman
Re: Door Pin Bushing Removal
« Reply #15 on: Thursday,September 15, 2022, 02:54:44 PM »
That was a good article!
I was thinking of a similar solution - pulling everything out and epoxying in new bushings at the correct alignment. This method is probably better, as it bores out existing for a sleeve.
1973 Europa TCS
« Reply #16 on: Thursday,September 15, 2022, 04:28:31 PM »
I liked the article too. I know it’s not the area of this thread but when he talks about “fiberglass cloth”, he really means fiberglass mat. I looked closely at his pictures and he definitely does not use cloth.
I think copper is too soft and would use brass or stainless or carbon steel instead.
If the upper bobbin was in good enough shape, I would use that and a 1/2” rod (maybe a hinge pin) to align the tube rather than rely on just tape as he seemed to. That aside, I’ll bet when he finished his car, the body alignment and panel contours were phenomenal! To say they were surely better than the factory fit would be understatement!
« Reply #17 on: Thursday,September 15, 2022, 05:22:10 PM »
If you haven't done it before, you can reach the top of the upper bobbin by removing the closing plate in the back of the front wheel well. Also the bottom of the lower bobbin, but that's a tighter fit.
« Reply #18 on: Saturday,September 17, 2022, 04:59:31 AM »
If the existing bobbin is decently solid, I'd leave it. If I recall, the Europa manual has pretty good instructions on how to install a new one.
There's all sorts of thin walled brass bushings available.
Here in the antipodes, common sizes like 1/2 inch are usually available from bearing suppliers. There are also split versions if that helps.
Offline cazman
« Reply #19 on: Wednesday,October 12, 2022, 05:42:16 PM »
Well, I don't like the Banks door hinge style as much as I like the original style. After a 3rd attempt at fixing my door sag, I spent real time some time playing around. Here is what I have concluded:
The Banks hinges came with my car and  I do not have the directions, but mine rotate against the car-body bobbin. I say against, as the shaft on mine didn't really insert into the bobbin like a shaft in a bushing. More like they ride on it via a chamfer that is machined on the hinge pin. I suppose, as they are brass, they wear in. However, it seems to me that they can wear the bobbin out of round too. That was my situation.
So, I bought the original style in SS from RD Ent. I drilled and bushed the top bobbin with a thin copper plumbing fitting as some have mentioned above. Before I put it in, I ground a flat near the top of the hinge rod and flattened the bushing on one side to match in order to keep the hinge rod from rotating. I can see that it is very easy for the shaft to turn in the bobbin rather than it being stationary. If the rod rotates it will wear the bobbin / bushing causing sag. I made new abrasion washers and installed the set-up the usual way. I am very happy. They seem much better than the Banks. Not knocking Banks, as maybe mine were not installed correctly, causing bobbin wear.
1973 Europa TCS
« Reply #20 on: Wednesday,October 12, 2022, 10:08:09 PM »
[...] Before I put it in, I ground a flat near the top of the hinge rod and flattened the bushing on one side to match in order to keep the hinge rod from rotating. I can see that it is very easy for the shaft to turn in the bobbin rather than it being stationary. If the rod rotates it will wear the bobbin / bushing causing sag.
Do you have a pic of what you did to the pin & top bushing?
If I recall, one of our forum members (apologies, can't remember who?) attached an arm to the top most end of the pin which holds the pin stationary in relation to the body. This forces the door bushes to act as the hinge point instead of the bobbin.
As far as I can see, and not having experience with the Banks design, they all suffer the same 'deficiency' in that they allow the pin to rotate in the bobbin.
Happy to be corrected.
« Reply #21 on: Wednesday,October 12, 2022, 10:23:59 PM »
Well done, that is exactly the problem with the original & replacement hinges. The Banks brass ones are better because they don't corrode anything like the steel door bushes, but if they wear and grip the rod then what you've determined is exactly the problem, the soft aluminium (?) bush in the body goes.
Your solution is far neater than the one I did (pin the shaft above the top bush in the cavity behind the front wheel well) but it's going to work equally well.  I did my mod shortly after getting the car because mine was also wearing the body bush but fortunately I was friendly with the local specialist who warned me of the consequences.
That would be what, '87, '88 ?  I took the doors off for a refresh in 2018 and the steel OEM door bushes still rotated freely on the (still stationary) stainless rod.
You've just made a "fit and forget" mod  ;)
Offline cazman
« Reply #22 on: Thursday,October 13, 2022, 04:39:08 PM »
Here is a picture of how I formed the "D" bushing to match the flat I made in the rod (used a small hammer). This rod was just scrap I had to experiment with. I put a dab of epoxy on the flat O.D. of the bushing to fill the gap and hold the bushing in place inside the bobbin. Hopefully just enough to do the job, but not enough to make it permanent.
1973 Europa TCS
« Reply #23 on: Thursday,October 13, 2022, 06:58:56 PM »
Thanks for the pics, cazman.
That looks simple and effective.  8)
« Reply #24 on: Monday,October 17, 2022, 09:46:55 PM »
Just had a thought, cazman.
What keeps the pin from falling down?
Is the lower split pin sufficient?
« Last Edit: Wednesday,October 19, 2022, 06:59:09 AM by GavinT »
Offline cazman
« Reply #25 on: Tuesday,October 18, 2022, 02:12:20 PM »
Just the cotter pin that goes through the rod. The lower hinge stops it.
1973 Europa TCS
