Happy Halloween y'all! I bring news!
First the good: I fully disassembled, cleaned and rebuilt the shoe adjusters for both rear brakes and that allowed the drums to just slide over the new shoes. Thanks for the link Dakazman your thread on it was very clear and helpful!! It was still a tight fit but removing all the grime and grit from the adjusters allowed them to move enough to clear the drums. I was also able to build the brake line from the master to the junction block and got the system properly bled. The car stops amazingly well! I've never had a car with proper non-boosted brakes, let alone one so light! The charging system has also been hooked up. I think the battery I had laying around the garage that went in the car is quite old and doesn't hold a charge so I can't establish whether or not charging system is functioning aside from giving the expected 14v measured with a multimeter. Lastly the brake lights have been hooked up and seem to function as designed.
Now the bad: out of nowhere the carb has started flooding so quickly and with so much fuel that it chokes out the engine. It's as if someone turned on a tap and I can watch as the carb spills over with fuel. At some point someone installed a Weber DGEV 32/36 progressive 2-bbl downdraft carburetor so I'llm take the top cover off and clean out the needle valve with either carb cleaner or compressed air. Taking the top plate off probably means ruining the gasket so I'll likely have to replace that too. The two inner bolts holding the carb to the manifold seem near impossible to get to so I'm hoping to not hav etc take the whole carb off. The only thing stopping me from rebuilding or replacing the carb is wanting to eventually (hopefully soon) upgrade to DCOE manifold but it may not be avoidable. The car was running so well and then all of a sudden its gone to hell so I'm believing currently its just crud in the carb but we'll have to see...
The second bit of bad news is tat I'll have to send the water pump back to RD Ent. The pump I've been sent appears to have a whole between where the heater hoses go that isn't present on my pump currently on the car. I'll try and get pics soon but I have neither the fitting intended for the orifice nor the desire to seal the hole with JB Weld or TIG. Hopefully I can get the pump swapped out for one that'll be a direct fit, but if not I'll figure it out.
I'm quite frustrated by it all but that's just part of it. I'll take some time to learn more about the carb and calm down. They seem very popular swaps on old MGs and 22RE powered Toyota trucks so There's gotta be a lot of knowledge out there.
