I went with the Autosparlks offering for the new wiring harness and its already arrived, 2 days early in fact! Though it its possible to fix the individual bad wires in the harness i figured that it may be a good idea to get a new harness given that its made with modern components and construction methods and its also not 56 years old! Aside form needing to replace the fuel pump and brake master cylinder (as well as bleed the brakes) the wiring was the biggest hurdle from getting the car running, at least that I'm aware of now. I hope to begin pulling the harness and getting to swapping them this weekend. The project has no time frame and I have no idea how long it'll take me to get it done but at least I can begin!
Dakazman yes I would appreciate you sending me a higher res version of the wiring diagram! Thats something I'll definitely need consult throughout this process.
JB I'll be sure to double check that I wire it in the correct orientation and if I run into overheating issues I'll double check that first!
Related to the wiring does anyone know of a company that may have a set of door lock barrels and matching ignition barrel? I'd really like to only need one key. If no one has them all as a set, does anyone know which of the variation of lock barrels a 67 S1a used? I've done some searching on line and it seems the R16 used several key variations throughout its production run, starting with a single sided key and moving to a couple different double sided keys. Can anyone tell me what the early Europas used?
Also did the early Europas use Lucas or Renault ignition switches?
