Author Topic: Feedback on aluminium radiator ?  (Read 633 times)
Offline TC2000
  • Elan, Seven, Europa
« on: Tuesday,August 30, 2022, 02:42:12 AM »
Hi All,
Do you have feedback on alloy radiator proposed on eb@y?
Many shown for sale, sopposedely made in china.
Mine original one is pretty rotten with unidentified bits wandering inside. I am cosidering fitting new rad and fan.
Thanks
Re: Feedback on aluminium radiator ?
« Reply #1 on: Tuesday,August 30, 2022, 05:35:11 AM »
The rads on offer vary in the thickness of the core.  The supplied fans are all cheap junk.
Offline TC2000
« Reply #2 on: Tuesday,August 30, 2022, 08:54:28 AM »
You are right: I see many 62mm and a few 86mm thickness proposed.
Original unit looks around 85mm and coper core. I wonder if the 62mm do the job…
Offline Blitzen
« Reply #3 on: Tuesday,August 30, 2022, 09:01:22 AM »
Why would you consider less surface area with a less conductive material?  Seems like a recipe for overheating issues but I'm no expert.  :confused:
« Reply #4 on: Tuesday,August 30, 2022, 09:09:04 AM »
Why even take the risk?  Go for the thicker rad.  And, get a much higher output rad fan.
« Reply #5 on: Tuesday,August 30, 2022, 10:13:58 AM »
I took my 72 TC deliberately into heavy traffic on a hot day (30'C) to see if it would cope.
The rad measures 70mm thick.
I had no problems.
I use an over-ride switch in case the thermostat doesn't kick in. Just a wire that is switched to earth on the bottom of the dash by the steering wheel.
Offline TC2000
« Reply #6 on: Tuesday,August 30, 2022, 11:48:34 AM »
Thanks for feedback, is it an aluminium rad as advertised on ebay?
« Reply #7 on: Tuesday,August 30, 2022, 01:59:31 PM »
Yes, the very same, with the strange BSP thread for the otter switch.
« Reply #8 on: Tuesday,August 30, 2022, 02:38:30 PM »
I bought the $135 one because it is thicker...will be awhile before the car is going though.
