Author Topic: Quick Release Luggage Tray  (Read 1064 times)
Offline 2766R
« on: Saturday,August 20, 2022, 11:50:13 AM »
I would like to pass along a mod I did a while back.  An easy to remove luggage tray makes life so much easier when preforming routine maintenance.  The pictures, I believe, do a better job of explaining than many typed words.
Notes: 1) the Quik_Latch used is: https://www.summitracing.com/parts/qul-ql-25-s15
           2) The large support washers are made from 1/16 aluminum X 2 1/2" dia.
           3) I made up a couple of hat sections from aluminum round stock to center the latch pins.  This was done to, hopefully,
               eliminate re-centering the latch pins in the event the cross beam is removed and reinstalled (Not absolutely
               necessary)
            4) The tray insert is just a piece of cardboard from a large box with a piece of cheep carpet from a local auto parts
                store attached with spray adhesive.
I can remove and re-install the tray as quickly an F1 car entering and leaving the pit lane!
Gerry
« Last Edit: Saturday,August 20, 2022, 11:52:42 AM by 2766R »
Re: Quick Release Luggage Tray
« Reply #1 on: Saturday,August 20, 2022, 11:56:58 AM »
Nice.  I used druz fittings in the floor and clips for the rear:
https://jbcollier.smugmug.com/Lotus-Europa/i-RBKK3qz/A
« Reply #2 on: Saturday,August 20, 2022, 12:28:52 PM »
That's very nice!  :beerchug:
Offline Blitzen
« Reply #3 on: Saturday,August 20, 2022, 12:32:24 PM »
Thanks for sharing.
