Author Topic: Facet cube  (Read 321 times)
Offline califkid_66
Facet cube
« on: Friday,August 12, 2022, 11:37:34 AM »
Where do you install the facet fuel pump I have all the electrical figured out in stuck on routing the fuel line and where to install the pump I have two fuel tanks but I’m using only the passenger side tank for now pictures would help thanks
Re: Facet cube
« Reply #1 on: Friday,August 12, 2022, 12:04:11 PM »
Facet recommends that the pump be mounted as low as possible. I mounted mine inside the frame rail near the cutout for the oil filter. I've attached two pictures that hopefully give you enough context to see what I mean.
Offline califkid_66
Re: Facet cube
« Reply #2 on: Friday,August 12, 2022, 12:42:51 PM »
Thanks for the info and pictures but where did you pass the fuel lines did you pass them under the frame thanks again
Re: Facet cube
« Reply #3 on: Friday,August 12, 2022, 01:12:11 PM »
There should be holes near the base of the "legs" where they join to the backbone where the fuel lines go.
