Author Topic: Thackery Washer Gap  (Read 1438 times)
Re: Thackery Washer Gap
« Reply #15 on: Sunday,September 04, 2022, 11:33:29 AM »
You need some flex or high rpm vibrations will emulsify the fuel in the float bowl leaning the mix drastically.
Offline cazman
« Reply #16 on: Sunday,September 04, 2022, 02:08:45 PM »
I am trying to diagnose my engine sputtering after 4,000 rpms. That is why this topic interests me.
Here is what was on my car and running well, until my recently rebuild. I popped open the cross-over adapter to see what was in there. Its just normal gaskets. Not sure how I could even get flex into this, if it needed it.
1973 Europa TCS
« Reply #17 on: Sunday,September 04, 2022, 04:17:53 PM »
That is a custom made adapter/balance pipe.  Mill a circular recess in the face to the carb for an o-ring.  You will have to lightly glue it in place to hold it while you assemble everything.  You will also need thackeray washers underneath the nuts.
Offline cazman
« Reply #18 on: Sunday,September 04, 2022, 05:19:08 PM »
I may someday, but I put it back together and changed cap and wires. All good!
1973 Europa TCS
« Reply #19 on: Sunday,September 04, 2022, 06:03:38 PM »
Glad it is running better but please fix the carb mounting.  High rpm leanness will kill your engine.
