Author Topic: Europa TC added to the Herd!  (Read 31116 times)
Offline wilkrod
Re: Europa TC added to the Herd!
« Reply #30 on: Sunday,July 17, 2022, 10:23:24 AM »
BDA,
Thanks, I understand your point, I have been doing EFI systems for 20 years, was taught to always use AN fittings. I moved away from the SS braid about 5 years ago now use Starlite exclusively with AN fittings. I don't know if you can see in the pics, but the output of the fuel pump is just hose with a hose clamp on the check valve, also the fuel filter is only low pressure plastic. Everything I see in total just makes me very uncomfortable about the plumbing, wiring. The other key point that convinced me to go with the webers is the obsolete ECU, I would end up spending as much on a modern ECU as what the webers will cost. Many years ago before EFI systems were common, I converted a Porsche 924 from the Bosch electro/hydraulic injection to webber DCOEs, and it was a great, simple system, ran great.
Jeff
2021 Evora GT
1886 Turbo Esprit HCI
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
2022 Infiniti Q60 (Wife's)
2022 Hyundai Santa Cruz
« Reply #31 on: Sunday,July 17, 2022, 10:52:46 AM »
I have to admit that hose technology has kind of passed me by since I was an Earls distributor. I am smart enough, at least, to match the hose with the expected pressure! That goes for modern automotive electronics too. I hear of people using ECUs with Webers and assume there must be an advantage - those things ain't cheap - but I just don't see it.
I hope to hear more about your build!
Offline wilkrod
« Reply #32 on: Thursday,August 04, 2022, 10:54:14 AM »
Hi all,
Well doors are nicely aligned, took three of us, all engineers to do it! Learning curve was pretty shallow, drivers door took about 4 hours, passenger only about 20 minutes. I received my 123 distributor, and Pierce has shipped a pair of 40DCOE webers jetted per Wilkins book. I will start removing the injection while I wait for the webers. Thats it for now.
Regads
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #33 on: Thursday,August 04, 2022, 11:02:00 AM »
Regads
Can you tell us what jets you are using, as I have mixed information on what to use.
Offline wilkrod
« Reply #34 on: Thursday,August 04, 2022, 02:54:09 PM »
These are from the Wilkins book on the TC.
choke: 33mm
main jet: 120
air-corrector jet: 155
slow-running jet: 50F8
accelerator-pump jet: 35
accelerator-pump stroke: 10mm
starter air jet: 100
starter petrol jet: F.5/100
emulsion tube: F11
Needle valve: 1.75
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #35 on: Friday,August 05, 2022, 12:13:45 AM »
Thanks for that.
Is that for Federal cams?
Any idea what sort of BHP that should produce?
I have a free flow exhaust system and manifold (header), and a gas flowed head. Otherwise standard spec with Federal cams.
Currently 2520R pulls very cleanly after about 2500 revs, but below that it seems unhappy, a bit like holding a racehorse back when it wants to gallop off.
Offline wilkrod
« Reply #36 on: Friday,August 05, 2022, 06:53:39 AM »
My best advice short of tuning on a Dyno would be to install a wideband O2 sensor that can data log to see where your A/F ratio is, also check your ignition advance curve to make sure it is appropriate.
Regards
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Offline wilkrod
« Reply #37 on: Saturday,August 27, 2022, 11:20:07 AM »
Out with the old, in with the new.
The throttle bodies are actually Jenvey units badged as luminition.
Need to figure out how to put the distributor in correctly, hoping timing marks are on the flywheel.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Offline TheKid#9
« Reply #38 on: Saturday,August 27, 2022, 11:27:43 AM »
Wilkrod - I would like to know what boss you have for the steering wheel and column to fit that steering wheel. Do you happen to know what it is or have paperwork on it? I wouldn’t mind doing something like that to my Seven S4.
Offline wilkrod
« Reply #39 on: Saturday,August 27, 2022, 02:44:06 PM »
What steering wheel are you referring to?
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #40 on: Saturday,August 27, 2022, 04:18:19 PM »
Marks should be on the flywheel; alternatively, in Wilkins' book, is a diagram of the position of the #4 cam lobes when #1 is at TDC, which you can see if you take off the oil filler cap.  From there, it's easy to preset the dizzy to point to the #1 lead on the cap and install (usually, all 4 wires exist to the rear pointing at the 9 o'clock position (relatively speaking).  Just what I found.
Offline wilkrod
« Reply #41 on: Sunday,August 28, 2022, 07:38:09 AM »
Bryan,
Thanks for the info.
Silly question, on the dizzy cap, what cylinders go to which connections on the cap?
My car didn't use a dizzy cap.
Thanks
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #42 on: Sunday,August 28, 2022, 07:49:31 AM »
The firing order is 1,3,4,2, so it all depends where your rotor is on TDC on #1 cylinder when the cam lobes are pointing apart on #1, and pointing towards each other on #4, seen at the oil filler cap.
Offline wilkrod
« Reply #43 on: Tuesday,September 06, 2022, 11:44:04 AM »
Hi all,
While cleaning out the fuel tanks, was looking at the data tag on the NG3 Trans. It is stamped with NG3 S20. Searched the Renault docs on the NG series, and couldn't find that suffix listed. The trans came from Banks if that helps, anyone seen that suffix before?
Thanks
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #44 on: Tuesday,September 06, 2022, 01:12:02 PM »
I'm assuming that you've looked at the NG workshop manual (http://lotus-europa.com/manuals/misc/ng.pdf). Of course, there is no S20 suffix. Those tags can be bent up and wrinkled so that the suffix is hard to read. Maybe you could post a picture of your tag so you can get more opinions about what it says.
