Author Topic: Europa TC added to the Herd!  (Read 31117 times)
Re: Europa TC added to the Herd!
« Reply #105 on: Tuesday,September 26, 2023, 11:20:45 AM »
I wrapped the exhaust from the muffler to the headers. My header tubes are too close together to wrap them individually and I didn't want to wrap a bunch of tubes together. I was mainly trying to reduce the heat to the sump and the oil tank (which really belongs elsewhere but that's another story). I can't say it makes a difference or not.
I checked at the beginning of this thread and you suspect you have an NG5 tranny. That appears to be the weaker twin to an NG3 in that the NG3 has 4 planet wheels and the NG5 only has 2. I don't know if that should cause you any problems given that your motor should be stronger than a stock TC motor, but you might want to check on that or at least keep it in mind.
Please let us know how it comes out when you get her on the road.
« Reply #106 on: Tuesday,September 26, 2023, 12:01:32 PM »
What is the rod going to the bracket on the tranny?
« Last Edit: Tuesday,September 26, 2023, 06:26:41 PM by TurboFource »
« Reply #107 on: Tuesday,September 26, 2023, 12:44:51 PM »
That rod is used to help make the linkage rotate when you move the gear shift from left to right. The linkage pivots on the end you can't see. It's similar to the 336 linkage, if you've seen that. I've attached a couple of pictures of mine which works the same way.
« Reply #108 on: Tuesday,September 26, 2023, 06:29:20 PM »
These cars certainly have unusual shift linkages….
Offline wilkrod
« Reply #109 on: Wednesday,September 27, 2023, 07:05:55 AM »
Guys,
Thanks for the input.
It is indeed an NG3, found the data tag a while back.
Jeff
2021 Evora GT
1886 Turbo Esprit HCI
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
2022 Infiniti Q60 (Wife's)
2022 Hyundai Santa Cruz
« Reply #110 on: Wednesday,September 27, 2023, 08:35:55 AM »
Good! The NG3 is better. As I’ve posted before, it’s ironic that parts for the 3xx transaxles are easier to find. I only recently found the last bearing I needed for my rebuild. In the near future I’ll be posting the parts and where I got them.
Offline wilkrod
« Reply #111 on: Thursday,September 28, 2023, 03:18:20 PM »
Solved my issue with the hole in the back end from the previous exhaust outlet.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #112 on: Thursday,September 28, 2023, 03:43:42 PM »
Pretty clever!  :beerchug:
Offline wilkrod
« Reply #113 on: Tuesday,October 24, 2023, 10:10:19 AM »
Hi all,
So finished the exhaust system after a recent distraction. Start the car with a touch of choke, fires right up, let it warm up a bit, check the carb synch, set the idle, give it a few revs, and notice gas dripping out of the cylinder #3 carb inlet where the horn bolts to the carb body! also started getting backfire thru #3. Promptly killed power, and gas continued to drip out the carb inlet for #3, all others were dry.
Any thoughts?
Regards
Jeff
P.S. the distraction was caused by the new silver vehicle.
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #114 on: Tuesday,October 24, 2023, 08:18:44 PM »
Check your float heights, fuel for debris and fuel pressure.
Offline wilkrod
« Reply #115 on: Sunday,November 05, 2023, 10:19:50 AM »
All good!
Had a vacum leak at the carb/manifold . Fixed that by tightening the nuts evenly. Started right up, no backfiring, synced the carbs, adjusted idle mixture, set idle speed. Now all that is left is getting the alternator rebuilt.
Regards
Jeff
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
Offline wilkrod
« Reply #116 on: Wednesday,November 08, 2023, 09:42:02 AM »
Hi All,
So my alternator guy says my Delco DN460 can't be rebuilt.
Picked up a WAI 14030N which fits.
My problem is getting it correctly wired as the connections are labeled with nothing I recognize. Anyone know how this is hooked up?
Many thanks.
Jeff
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #117 on: Wednesday,November 08, 2023, 12:38:32 PM »
WL = warning light - NY wire (brown wire with a yellow tracer)
B+ = battery positive - large N wire (brown)
You can get a connector kit for this alternator:
https://rimmerbros.com/Item--i-GEU250
Most British sports car parts suppliers have them.
Offline wilkrod
« Reply #118 on: Wednesday,November 08, 2023, 03:19:44 PM »
JB,
Thanks so much, you rule!
So no sense needed, nor separate ground?
Ordered the connector, perfect.
Regards
Jeff
Jeff
2021 Evora GT
1972 Europa TC
1983 Mondial QV
1999 Ducati 748
« Reply #119 on: Wednesday,November 08, 2023, 03:35:11 PM »
Alt is grounded through the mounting bracket to the bell housing/engine.
