Author Topic: 336 output shaft oil seal  (Read 779 times)
Offline califkid_66
« on: Tuesday,June 21, 2022, 10:05:46 AM »
is there a way to know what size seal i need without removing the nut
reason is im ordering the oil seals and i don’t have the tool to remove them yet
« Last Edit: Tuesday,June 21, 2022, 11:08:39 AM by califkid_66 »
Offline califkid_66
Re: 336 output shaft oil seal
« Reply #1 on: Thursday,June 30, 2022, 02:08:49 PM »
removed my oil seal with homemade low budget tool
Offline Footer
« Reply #2 on: Thursday,August 17, 2023, 11:00:11 AM »
Would you share the process you used to make the wrench for the nut.  I'm hesitant to spend $126 for the one at RD.
Thanks
« Reply #3 on: Thursday,August 17, 2023, 11:41:10 AM »
Joji recommended a motorcycle clutch tool to me (https://www.ebay.com/itm/354390198069). It works very well. I've also bought a PVC pipe cap that looks like it can be modified easily but the clutch tool works well enough that I haven't been sufficiently motivated to do it.
« Reply #4 on: Thursday,August 17, 2023, 12:24:48 PM »
A regular W1270 (I think that is right) socket for a 4WD works fine
Offline Blitzen
« Reply #5 on: Thursday,August 17, 2023, 01:26:25 PM »
A made the tool out of pvc pipe with a clean plug on the other end to turn the tool.  Pretty simple to make, center pipe over flange and mark each rib.  Used a dremel to cut out for each rib.  Worked perfectly but didn’t fit the NG3 flange nut.     So bought the W1270 socket and it fits both flange nuts.
« Reply #6 on: Thursday,August 17, 2023, 01:59:12 PM »
Thanks
   Footer, I have one I made  that I can send up to you, just pay round trip postage. It will fit in a USPS  7.95 box
 dakazman
« Last Edit: Thursday,August 17, 2023, 02:14:34 PM by dakazman »
Offline Footer
« Reply #7 on: Thursday,August 17, 2023, 04:10:31 PM »
Thanks for all the suggestions.  Some I will have to look into further and go from there.
Thanks for the offer Dakazman, I’m not ready to tackle it just now, probably late September or October, but I may take you up on the offer then.
BDA, the clutch tool your suggesting looks like it would damage the nut but, knowing you, it must work well.
Thanks again!
« Reply #8 on: Friday,August 18, 2023, 01:33:02 AM »
Print this out and fabricobble one from some PVC plumbing pipe?
I can add more concentric circles to make it a little easier to find the centre if you like.
Offline Footer
« Reply #9 on: Friday,August 18, 2023, 06:10:44 AM »
Nice drawing Gavin.  I’ve down loaded and printed it.
Thanks
Offline califkid_66
« Reply #10 on: Tuesday,August 22, 2023, 07:25:02 PM »
Hi Footer !!
Sorry for the late response
I just took a pipe big enough to fit where the slots are leaned the pipe against the slots and with a marker I made lines on the pipe where the slots were
after I drilled on the line’s with a drill bit a bit wider than the slots and when I drilled i didn’t drill completely at the end I left a quarter inch made it easy to drill then I cut of the end of the pipe right in the middle of the holes didn’t take much time to make
A friend of mine told me someone used a pcv pipe heated it up pushed it against the nut to get the shape and when it cooled down he used it to unscrew the nut
Hope this helps !!
« Reply #11 on: Wednesday,August 23, 2023, 03:33:20 AM »
The socket I mentioned earlier works fine, costs about $12 and also fits the lock ring that holds the sending unit in the gas tank ….  :confused:
« Last Edit: Wednesday,August 23, 2023, 03:35:11 AM by TurboFource »
