Author Topic: Tcs clutch plate  (Read 398 times)
Online Sparkrite
Tcs clutch plate
« on: Friday,June 10, 2022, 08:07:11 AM »
I have just had my original low mileage borg and beck clutch plate re lined. However I am not certain that all is good. Firstly I can not find the specifications for the thicknes in the on line manual, and stupidly I did not measure my old one before sending it off. Also my original linnings had a thin sheet steel backing, and that is on both linnings not the central part. The new linnings do not have this and are just  riveted on as normal. I have looked at a NOS clutch disc I have for a 60s sprite and the linnings are also backed with steel sheet.
Re: Tcs clutch plate
« Reply #1 on: Friday,June 10, 2022, 08:49:25 AM »
Clutch plate relining is great for big rigs, etc.  In theory it should be fine for cars too but in my experience it does not work out well.  Did a few but always ended up having to switch it out for new.  Buy a new, matched, pressure plate and disc kit.  That way you only do it once and it last a long time.
