Author Topic: Output shaft shim size  (Read 1358 times)
Offline Fotog
  • 72 Twin Cam
Re: Output shaft shim size
« Reply #15 on: Wednesday,June 08, 2022, 10:49:07 AM »
I just measured some that I have, from RD Enterprises.
25.4 I.D., 35 O.D.
Vince
« Reply #16 on: Wednesday,June 08, 2022, 12:32:18 PM »
Spot on.
It's a 1" ID and an 1 3/8" OD
« Last Edit: Wednesday,June 08, 2022, 12:35:26 PM by jbcollier »
Offline califkid_66
« Reply #17 on: Thursday,June 09, 2022, 11:57:38 AM »
they are not so hard to find to bad it’s not the same for roll pins
« Reply #18 on: Thursday,June 09, 2022, 12:42:03 PM »
outer is 7mm x 35mm
inner is 4mm x 35mm
outer placed with closed end towards transaxle, inner opposite.
Offline califkid_66
« Reply #19 on: Thursday,June 09, 2022, 01:36:43 PM »
i have a s2 federal so in imperial it’s the dimensions JB wrote
what do mean by outer and inner ?
the only shims i knew about were the one close to the transmission to adjust so it doesn’t move when  roll pins are put in
am i missing something
« Last Edit: Thursday,June 09, 2022, 01:44:49 PM by califkid_66 »
« Reply #20 on: Thursday,June 09, 2022, 01:55:50 PM »
I think Brian was talking about the roll pins, not the shins, in response to calfkids comment above
Offline califkid_66
« Reply #21 on: Thursday,June 09, 2022, 02:15:36 PM »
ok thanks for clarifying i was a bit confused
makes sense so now we have all the measurements we need!!
Offline RafM
« Reply #22 on: Saturday,June 11, 2022, 08:01:04 AM »
The 37mm o/d - 26mm i/d shims I ordered have arrived, they are a perfect fit.
« Reply #23 on: Saturday,June 11, 2022, 08:30:09 AM »
Good news.
