Author Topic: Output shaft shim size  (Read 1357 times)
Offline RafM
« on: Tuesday,June 07, 2022, 04:35:53 AM »
Would anyone know know the correct size for these shims.
I don't have any to measure but looking at the gearbox I think 35 o/d with a 25mm hole will work.
The usual suppliers stock shims but they sell them individually at high cost, I can buy 10 for the cost
of a single and would rather get a good supply of different thicknesses to use as required.
Thanks.
Re: Output shaft shim size
« Reply #1 on: Tuesday,June 07, 2022, 06:29:53 AM »
I have a spare transaxle lying around and the output shaft is 25.4mm-ish (it's a bit dirty) in diameter.  The outside diameter of the half shaft yoke is 36.3mm-ish (it's a casting).  So either 1" ID and 1 7/16" OD or 26mm ID and 36mm OD.
Offline RafM
« Reply #2 on: Tuesday,June 07, 2022, 06:37:40 AM »
Thanks JB, I'll re-check the measurement I made on my output shaft, looks like 26 id - 35/35 o/d will work fine.
Offline califkid_66
« Reply #3 on: Tuesday,June 07, 2022, 02:25:49 PM »
would you happen to know approximately how many shims per side i have a little bit of loose and i want to order shims and roll pins but at 2.50 per shim plus shipping witch is really  expensive it would be nice to know
i dont want to dismantle before having the parts
thanks
« Last Edit: Tuesday,June 07, 2022, 03:02:55 PM by califkid_66 »
« Reply #4 on: Tuesday,June 07, 2022, 03:18:44 PM »
Your existing shims should be in good shape. So measure the slop and order shims to fill it, intending to use the existing ones as well?
Offline califkid_66
« Reply #5 on: Tuesday,June 07, 2022, 03:39:31 PM »
how would you go about mesuring
cause the only option i see is to take it apart and add shims until it’s a thight fit for the roll pins is there a way to stick in a feeler gage
« Reply #6 on: Tuesday,June 07, 2022, 03:44:31 PM »
Hold a dial indicator on the yoke, then move it in-out and see how much it moves?
« Reply #7 on: Tuesday,June 07, 2022, 10:40:39 PM »
thanks
I understand that, I don't like ripping a car apart until I've got everything ready to fix it.
But on buying shims, I bought mine from an industrial supplier and they were relatively cheap, nothing like 2.50 each. If you do a search for something like "shim washer" you should find a local supplier. They are nothing special, a common engineering component. I vaguely remember I bought the minimum order of 10 (?) in 0.005" & 0.010" sizes and I wouldn't have done that at 2.50 each !
Offline RafM
« Reply #8 on: Wednesday,June 08, 2022, 03:52:24 AM »
I had no shims to measure up in the first place. After measuring up the output shaft and getting some advice
here I settled on 37mm o/d & 26mm i/d shims.
I have purchased 30 shims in various thickness from this place, the cost was £14.00, including shipping, around 45p each;
https://springfasteners.co.uk/product-category/shimsupport-washers-din-988/
There will be many similar suppliers in the US, just have a search for circular, carbon steel shim washers.
Offline Sparkrite
« Reply #9 on: Wednesday,June 08, 2022, 04:09:25 AM »
Im also needing some shims but my question is does it matter if they are steel,carbon steel,high quality steel or stainless steel., all as I have seen advertised. btw I was going for 25 x 35 size as I dont think the 1/2mm loss on the outer edge is a big deal.
« Reply #10 on: Wednesday,June 08, 2022, 05:18:50 AM »
25mm ID is too small.
Offline califkid_66
« Reply #11 on: Wednesday,June 08, 2022, 06:28:46 AM »
would 37 outside be to big
cause they have 25-36 or 26-37
« Last Edit: Wednesday,June 08, 2022, 06:34:12 AM by califkid_66 »
Offline RafM
« Reply #12 on: Wednesday,June 08, 2022, 06:33:39 AM »
Ideally I would have chosen 26 - 36 if they were available, but having measured where the oil seal sits the 37 should fit, if not it's very easy to take a little off the outside.
When they arrive I'll post up with the results.
« Last Edit: Wednesday,June 08, 2022, 06:37:00 AM by RafM »
« Reply #13 on: Wednesday,June 08, 2022, 07:27:32 AM »
You're going to buy 150?!
Offline califkid_66
« Reply #14 on: Wednesday,June 08, 2022, 09:19:48 AM »
no !! was just checking  i dont need that much
« Last Edit: Wednesday,June 08, 2022, 09:26:19 AM by califkid_66 »
