Author Topic: facet fuel pump  (Read 550 times)
Online califkid_66
facet fuel pump
« on: Friday,May 27, 2022, 11:40:55 AM »
witch facet fuel pump should i get for a stock
821 renault engine
if you have model number and pressure
thanks
Re: facet fuel pump
« Reply #1 on: Friday,May 27, 2022, 11:49:36 AM »
This is a very comprehensive listing of Facet fuel pumps:
https://www.pegasusautoracing.com/advcat.asp?CategoryID=FACET
One that puts out no more than 3.5 psi would be fine.
Online califkid_66
Re: facet fuel pump
« Reply #2 on: Friday,May 27, 2022, 12:04:12 PM »
thanks!
Online califkid_66
Re: facet fuel pump
« Reply #3 on: Friday,May 27, 2022, 01:03:45 PM »
not sure witch one to get  40178 or 40366
they are both at 3.5 psi and 15 gph
40178 is good for 150 hp 40366 good for 80hp
i do have à weber 32 36 instead of the solex
thanks again
Re: facet fuel pump
« Reply #4 on: Friday,May 27, 2022, 01:56:38 PM »
The only difference appears to be the connectors on the wires. They both have a ring connector for the ground wire but the 40366 has a TYCO (whatever that is) and the 40178 has a bare wire. See the technical info from https://www.facet-purolator.com/tech-information/ below.
Re: facet fuel pump
« Reply #5 on: Friday,May 27, 2022, 09:06:12 PM »
Virtually the same pump with only minor differences.
Online califkid_66
Re: facet fuel pump
« Reply #6 on: Saturday,May 28, 2022, 09:00:43 AM »
yes it’s the same pump different numbers but what bothered me was that in the description one was rated at 70 hp and the other at 150 hp witch is false
they both have 15 gph and to calculate for fuel pump rating
10 hp per gallon so they are both rated for 150 hp engines
so basically same pump
Re: facet fuel pump
« Reply #7 on: Saturday,May 28, 2022, 09:18:23 AM »
Am I missing something? When I go to the Pegasus page for 40178 it says, “ For low fuel requirements on engines up to about 80 horsepower…” When I go to the page for 40366 it says, “ For low fuel requirements on engines up to about 80 horsepower…”
Maybe you mis-clicked.  :)
Online califkid_66
Re: facet fuel pump
« Reply #8 on: Saturday,May 28, 2022, 11:01:40 AM »
you are right !! i read to fast in the description it says they offer pumps up to 150 hp
my bad !!
