Author Topic: Spigot bearing  (Read 373 times)
Spigot bearing
« on: Friday,March 18, 2022, 02:42:57 PM »
It looks like the spigot bearing in the flywheel is just a thin bushing (oilite I presume?),
does this hold up fine?
Re: Spigot bearing
« Reply #1 on: Friday,March 18, 2022, 10:14:10 PM »
TC engine uses a bronze bushing.  The Renault, a ball-bearing.  Either way, it only turns when the clutch pedal is depressed and the clutch disc is disengaged.  Good reason not to sit at a light in gear.
