Author Topic: Secondary Throttles on Stromberg Federal TCSs.  (Read 2989 times)
Re: Secondary Throttles on Stromberg Federal TCSs.
« Reply #15 on: Wednesday,March 09, 2022, 06:10:06 PM »
Those UK high balance tube manifolds are hard to find. I've been looking for one.
I thought the pooling of fuel problem in the US manifolds had to do with the manifold catching fire if there was a backfire or something, not that the pool caused variation in fuel/air ratios. It's all starting to sound like some legend whispered in the back rooms, than anything based in fact. (After that, I should probably go get my Nomex coveralls  >:D)
I'm thinking along the same lines; otherwise it would have surfaced a lot sooner than the 50 some odd years since these things hit the roads...Going to leave them unplugged; I think it's more important right now to set up the carbs per both the stromberg manual and the Lotus workshop books and go from there.
« Reply #16 on: Thursday,March 10, 2022, 05:46:02 AM »
Just some random photos
#1...as removed.  Neither carb had nuts on either of the bottom mounting studs.
#2...the secondary throttle body, sans the butterflies, and the adapter plates for the carbs cleaned up and the flanges (mostly) polished to present a good surface for the gasket.
#3...carb air chamber removed, will renew the diaphragms, and discovered the needles are the euro taper.  I have the original spec taper needles...wondering which would be more appropriate for this area?
#4...the plugs made to seal the secondary throttle openings made from the shaft of the butterflies and will be secured with high-temp epoxy.
(yeah, I wish I had a parts washer and maybe an ultrasonic tank.  Maybe in the next life...will clean up as best I can before reassembly.  Maybe I should hold off on reassembly and bring the secondary body down to the airport, seal off the openings, and bead blast the shell.  Buy a dunk can of carb cleaner and strip down to the bare bones and let the bodies soak?  Nah...I'll just keep on doing what I'm doing.)
« Last Edit: Thursday,March 10, 2022, 05:50:52 AM by Bryan Boyle »
« Reply #17 on: Thursday,March 10, 2022, 07:25:41 AM »
The pooling was associated with the low balance pipe manifolds fitted to UK Elans and Europas, not the US manifolds.
The high pipe was the cure.
« Reply #18 on: Thursday,March 10, 2022, 07:36:37 AM »
Thanks for the clarification!  Going to leave well enough alone, and get things as back to stock as I can...and correct the DPO happiness.
« Reply #19 on: Thursday,March 10, 2022, 10:08:50 AM »
Bryan, I like your reuse of the secondary shafts as plugs. Very Chapman!
When I got my car, back in 1989, and had to get it smogged, the needles and seats were worn enough I had to replace them. The old-Lotus mechanic I bought the car from recommended the Euro, floating needles. And all of that passed CA smog. (now it's grandfathered and I don't have to do that anymore)
« Reply #20 on: Friday,March 11, 2022, 06:19:56 AM »
Thanks for the compliment!
Quote
The needles in my car are the Euro taper, but whomever (and it wasn't the PO; going to start saying PPO, since the gent I bought the car from admitted that he was in over his head and was hoping someone like me would take it off his hands...) replaced them in the piston and never set the height correctly (there are a few other gotchas that I'm discovering...like 2" long idle adjust screws, which are just 6-32s but a case of the originals probably rolled off the bench, so the wrench just pulled something out of the parts box that fit..).  Just taking my time, correcting the issues, using new rebuild kits (from Joe Curto), and setting up per the manual as the starting point.
Once that is done...on to mucking with the brakes.  And, oh, yeah...got new throttle and choke cables.  Thinking replacing them is going to be a goat rodeo...a lot easier when the lump is out of the car, but not there yet, so...
« Reply #21 on: Friday,March 11, 2022, 11:31:39 AM »
***DELETIA***
Have cleaned up the threads on the pile of 5/16x24 nuts, ran a die down all the studs to clean up those parts, have a stack of new split and flat washers to use where needed, new thackery washers, new gaskets, new diaphragms, new o-rings, new floats, new needle valve, a gallon can of carb dip and a couple parts brushes.  Time to dig in, clean up, rebuild, and reinstall...
Finished first carb (rear carb...the front is almost there.)  New gaskets where needed, temp compensator checked and they're close, need to find proper size drift to set the butterfly shaft seals, needles set correctly, float level set for 11/16", but for now...polished (I know, geeky) the top cap...and need to set the initial settings on the bench per the manual.
Waiting for the gaskets for the base of the secondary throttle block to the head, and have new viton o-rings to set the adapter plates at the proper clearance on the secondary with new thackery washers and have ALL the proper 5/16x24 nuts and washers at the ready.  New teflon-lined throttle and choke cables coming...pretty sure that snaking the new cables will be a messy exercise...but needs be done.  More as it happens, stay tuned.  Headed towards seeing if I can get it started this weekend or next week.
« Last Edit: Friday,March 11, 2022, 11:35:21 AM by Bryan Boyle »
« Reply #22 on: Wednesday,March 16, 2022, 07:45:58 AM »
Runs.  Not sync'd yet.  And idle is up around 1700 even with needles backed out...still work to do (new throttle cable, new choke cable...)
« Reply #23 on: Tuesday,March 29, 2022, 09:02:09 AM »
Well...got new cold start cable (it's not really a choke) in with zero issues (except for making another blood offering through the chassis access hole in the cockpit...).  This is what I did...
1. Remove the inner cable from the new sheath (carefully...don't want to kink or start separating the strands at the cut end...), and put aside.
2. Remove the old cable assembly from the carbs and the mount under the armrest.  Toss in the bin.
3. Push the new sheath in through the front mount, slip the lock washer and nut over the sheath, and thread the sheath through the backbone out the back, tighten the nut down on the cockpit side,
4. Go into the front of the engine room, making sure the cable misses the pulleys and belt, and gently pull the end up along the passenger (right) side.  Now, the universal fit cable assembly that Ray sells is meant to be cut to length.  So, keeping a nice sweeping arc out of the chassis bulkhead (and supporting it with an adel clamp set on the cross-tube where the catch can would normally be) down to the front carb.  I used a dremel with a cut-off wheel to cut to length (using a set of dykes would crush the sheath), and then ran a needle file through the cut end to clean up any swarf.
5. Threaded the lightly lubed (I use LPS #2 from my days in an aircraft maintenance hangar...) inner cable through the sheath and out the other side in the engine room.
6. attach the cable to the clamp in the front carb, ensure the inner cable is pulled back all the way, and thread through the cable attach fitting on the cold start lever and tighten down the capture nut, leaving an inch or so past the fitting, again, using the dremel, cut off the excess inner cable.
7.  Check operation.  Pretty basic but still good to check that it works both all the way out (and the capture nut is tight) and all the way in.  (Just a note, you never set a cable up so that when you push it all the way in, the knob bottoms out on the ferrule; leave a little gap so that the controlled lever is at its stop, not limited by the cable bottoming out.  Just how I was taught when restringing control cables in airplanes...;))
Done.   Now, on to the throttle cable.  I'm thinking of leaving the existing sheath in place and just replacing the inner whilst lubing as I did with the cold start cable so I don't have to pull up the carpet on the driver side for now.  I'm going to ruminate on it a bit.
