Author Topic: Lotus Europa Race Car Collection  (Read 52743 times)
Re: Lotus Europa Race Car Collection
« Reply #90 on: Friday,October 04, 2024, 05:21:13 AM »
Mecky, why not run a higher front (and rear) rate? Mine is street/track and I started with 250lb front and kept going up. 650 now and it's a little rough but even 400lb wasn't too bad. If it's track only and smooth you can get away with quite a bit.
How much front camber do you run? It doesn't look like more is needed, just curious.
My next bar will be like Turboforce's but a hollow one.
Offline Mecky
    • Lotus Europa Racing
« Reply #91 on: Monday,October 28, 2024, 01:44:06 PM »
I can't really name a reason, these rates were just iterations from the basic set-up and the car's suspension was one of its best features over the years. It was very predictable and I was able to improve my lap times a lot. Other areas were much more important to improve, in order to make the car reliable and also faster.
My camber is -2.0° front and -1.5° rear.
