A Fram PH966B oil filter fits the Lotus TC. It is 2.984" wide. Looking at the pdf Mr. BDA posted, the o-ring diameter is 2.5" and should work just fine.
Some oil cooler take offs come with a built in oil thermostat which is very useful if you are fitting an oil cooler. That's the way mine is set up.
