I bought one of those "multipurpose tools" at Harbor Freight yesterday. I am using it to remove the poor glass work on the fiberboard panels in the rear of the cabin of my new bodyshell. So far I am using it to break through the areas that are clearly just fabric (no resin at all) and then I grab the area with a pair of pliers and pull.
What I have found is that there might be a bit of black dope like sealing material between the fiberboard and the fiberglass, then the previous owner "glassed over" that area with a layer of woven fiberglass. I am only dealing with the "inside" side for now, but will also address the engine compartment side as there is poor work there as well. This is where I am going to get my first practice dealing with fiberglass work.
I only started today, but tomorrow I am going to look at the underside and double check that the fiberboard panels are aligned correctly. If they are not, I am going to need to free up the fiberboard so I can get a better seal before I reglass the panels in place.
I know that I read in the past that these panels sometimes need to be replaced due to water incursion and that the fiberboards break down when they get soaked, so I will want to be sure that they are well sealed, which is why I started this project.
I haven't heard back from the Lotus Supply folks yet (re: new bodyshell prep,), but figure I must be on the right track so far. Any critiques on my angle here would be appreciated! Since I don't have another example to scrutinize, I am wondering if ALL of the fiberboard is to be glassed over, or only the areas adjacent to the bond line.
