Author Topic: Tcs engine tune issues  (Read 1582 times)
Offline Sparkrite
Re: Tcs engine tune issues
« Reply #30 on: Thursday,February 24, 2022, 11:50:54 PM »
I believe my distributor is the original federal lucas, model  25d  number 41225e. Whilst it may be ok to eliminate the vacume, the cam,weights and springs could do with changing to suit my webers. I found this which seems to detail what I should do.
https://lotuselan.net/forums/viewtopic.php?f=38&t=31358&start=
« Reply #31 on: Friday,February 25, 2022, 05:04:09 AM »
There are a number of options out there.
The first is to figure out what you have.  These cars are 50 years old.  Good lord knows what has been changed/modified over the years.  You need a way to measure your degrees of advance versus rpm.  You can invest in a timing light that measures degrees of advance, or, you can mark your flywheel.  It is easy to mark the flywheel using a simple set of steel dividers and a punch.  Measure the existing distance between TDC and 10° using the dividers.  Now you can mark off 10° increments, half way is 5°.  Next use a piston stop to check that your TDC mark is accurate.  Last, get an accurate tachometer (not the one in the dash).  Now, use the tach and timing light to plot out your advance curve.  Minor adjustments can be made by tweaking spring tensions, filing slots and stops.
Way off?  You can:
- send it to distributor specialist to set up properly
- replace it with a new distributor (still need to check it's advance curve)
- replace it with a programmable distributor (this is the route I went)
