Author Topic: Engine bracket right side dimensions  (Read 252 times)
Offline bert knip
« on: Wednesday,February 02, 2022, 10:16:36 AM »
Because I can not find one for sale second hand, I will be making on myself.
Is the rightside bracket the same as the left bracket, but then mirrored and a hole in it? Look like to be the case.
Otherwise has someone the dimensions for it?
Thanks Bert
Offline gideon
Re: Engine bracket right side dimensions
« Reply #1 on: Wednesday,February 02, 2022, 10:51:29 AM »
Just buy a new one, it'll be cheaper.  There are seven holes, including the big one, three bends at non-obvious angles, and one welded in tube section for the clutch cable.  Plus paint.
https://www.lotus-supplies.com/parts/chassis/mounts/engine-mount-rh-steel-s2/
Offline bert knip
« Reply #2 on: Wednesday,February 02, 2022, 12:42:44 PM »
Good advice, I ordered one.
Thanks Bert.
