Author Topic: Restore Cosmic wheels bright finish?  (Read 516 times)
« on: Tuesday,February 01, 2022, 08:30:49 PM »
Without sending my Cosmic wheels to England for re-cutting what is the best method to restore the bright edges?
I know they were originally cut, not polished.
Re: Restore Cosmic wheels bright finish?
« Reply #1 on: Tuesday,February 01, 2022, 09:18:25 PM »
I had a local wheel refinished do mine.  Turned out well.  If you have access to a big enough lathe, you could spin and cut/polish them yourself.
« Reply #2 on: Wednesday,February 02, 2022, 08:33:30 AM »
I think I need to find a scrap wheel to experiment on.
Offline gideon
« Reply #3 on: Wednesday,February 02, 2022, 09:04:57 AM »
I came across a nice explanation from one TVR owner on BAT who set up a wheel lathe in his own garage, using the bare car frame and hub then driving the bare wheel with an electric motor and belt.   It looked very doable.  His picture of the lathe is below
The listing is here
https://bringatrailer.com/listing/1974-tvr-2500m-17/
and the bit in the video where he explains what he did is here
https://youtu.be/3RUwRnUEr98?list=PLiDNv78G_ZVW-qTrzbaM1zlo4rcQtrMoZ&t=65
« Reply #4 on: Wednesday,February 02, 2022, 10:59:42 AM »
I may experiment with some cheap US made wheel first.
One concern is to not radius the edges.
Offline rjbaren
« Reply #5 on: Thursday,February 03, 2022, 05:48:49 PM »
I have been working on a set of Cosmic wheels for a few weeks.  I have been sanding and polishing the "bright edges" by hand.  I started sanding with 100 grit right on up to 1000 grit.  Finally some metal polish and four ought brass wool and then metal polish with a cotton cloth.  It's a bit tedious but also rewarding.
« Last Edit: Friday,February 04, 2022, 04:27:38 AM by rjbaren »
Offline HelpMyLotus
« Reply #6 on: Tuesday,February 08, 2022, 06:08:39 AM »
My father did ours by painting the wheels gold then using a DA sander to nip every rib.  It isn't polished persay but it is shiny.  He clear coated them after.
« Reply #7 on: Tuesday,February 08, 2022, 08:21:43 AM »
    If you have a bench grinder with a polishing pad, along with some green rouge you can buff that up to a nice mirror shine. you could also use a pneumatic die grinder with a polishing pad and the rouge.
« Reply #8 on: Tuesday,February 08, 2022, 09:19:08 AM »
Unless something goes sour at the last minute I have made a deal on a set of 15x5.5 Cosmic to fit my TR4.
Of course they also need restoration.
